Ir para o conteúdo principal
HP Chromebook 14-Q010DX Fan Replacement
O que você precisa
    1. HP Chromebook 14-Q010DX Fan Replacement, Keyboard and Touchpad: passo 1, imagem 1 %32 HP Chromebook 14-Q010DX Fan Replacement, Keyboard and Touchpad: passo 1, imagem 2 %32
      • Flip the laptop so the base of the laptop is facing you.
      • Using the #00 screwdriver, unscrew the 13 screws.
      Pergunte ao FixBot
      Comentar
    2. HP Chromebook 14-Q010DX Fan Replacement: passo 2, imagem 1 %32 HP Chromebook 14-Q010DX Fan Replacement: passo 2, imagem 2 %32 HP Chromebook 14-Q010DX Fan Replacement: passo 2, imagem 3 %32
      • Warning! When prying open a laptop it could require some force, but it also has fragile connectors underneath. Use caution so as to avoid breaking these connectors.
      • Start from the top right corner of the laptop and work clockwise with an iFixit opening tool or spudger to pry the keyboard from the frame of the laptop.
      Pergunte ao FixBot
      Comentar
    3. HP Chromebook 14-Q010DX Fan Replacement: passo 3, imagem 1 %32 HP Chromebook 14-Q010DX Fan Replacement: passo 3, imagem 2 %32 HP Chromebook 14-Q010DX Fan Replacement: passo 3, imagem 3 %32
      • Warning! Handle the flaps and ribbon cables with care to prevent damage.
      • Gently pull the keyboard in the opposite direction of the screen, so the wires beneath are exposed.
      • Lift the black flap and pull the blue ribbon gently towards you until it is disconnected.
      • Lift the white flap and pull the blue ribbon towards you until it is disconnected.
      Pergunte ao FixBot
      Comentar
    4. HP Chromebook 14-Q010DX Fan Replacement: passo 4, imagem 1 %32
      • Lift keyboard slightly and remove the strip gently to prevent damaging any parts.
      • The tape has no function other than to keep the wire tucked away.
      Pergunte ao FixBot
      Comentar
    5. HP Chromebook 14-Q010DX Fan Replacement: passo 5, imagem 1 %32
      • Set aside the detached keyboard.
      Pergunte ao FixBot
      Comentar
    1. HP Chromebook 14-Q010DX Fan Replacement, Fan replacement for a HP Chromebook: passo 6, imagem 1 %32 HP Chromebook 14-Q010DX Fan Replacement, Fan replacement for a HP Chromebook: passo 6, imagem 2 %32 HP Chromebook 14-Q010DX Fan Replacement, Fan replacement for a HP Chromebook: passo 6, imagem 3 %32
      • Remove the 3 screws around the fan.
      • Using your fingers or the spudger, disconnect the cable connecting the fan to the motherboard.
      Pergunte ao FixBot
      Comentar
    2. HP Chromebook 14-Q010DX Fan Replacement: passo 7, imagem 1 %32
      • Once the cable connecting the fan to the motherboard is revomed gently remove fan with hands.
      Pergunte ao FixBot
      Comentar
Conclusão
5 outras pessoas executaram este guia.
Kevin Piper
Membro desde: 01/16/15
1.602 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 17-2, Watkins Winter 2015 Membro de USF Tampa, Team 17-2, Watkins Winter 2015
USFT-WATKINS-W15S17G2
4 Membros
Autoria de 56 guias
1Comentário do guia
Add Comment:
Akshit Fnu - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 30
Ao todo: 4,293
