Ir para o conteúdo principal
HP Chromebook 11A G8 EE Speaker Replacement
O que você precisa
  1. HP Chromebook 11A G8 EE Speaker Replacement, Keyboard Assembly: passo 1, imagem 1 %32 HP Chromebook 11A G8 EE Speaker Replacement, Keyboard Assembly: passo 1, imagem 2 %32
    • On the bottom of the laptop, remove four 7 mm screw using a Phillips #1 screwdriver.
    • Using the Phillips #1 screwdriver, remove the two remaining 8 mm screws by the hinges.
  2. HP Chromebook 11A G8 EE Speaker Replacement: passo 2, imagem 1 %32 HP Chromebook 11A G8 EE Speaker Replacement: passo 2, imagem 2 %32 HP Chromebook 11A G8 EE Speaker Replacement: passo 2, imagem 3 %32
    • Flip the laptop over and open up the display.
    • Using the iFixit opening tool, carefully separate the palm rest from the bottom cover by working your way around the perimeter and prying it up.
    • You will hear an audible and tactile click or pop letting you know that you have unclipped a portion of the palm rest from the base enclosure.
    • Lift the palm rest of the laptops towards you, away from the screen.
  3. HP Chromebook 11A G8 EE Speaker Replacement: passo 3, imagem 1 %32 HP Chromebook 11A G8 EE Speaker Replacement: passo 3, imagem 2 %32
    • Carefully, lift the keyboard ribbon lock and disconnect the keyboard ribbon from the motherboard.
    • Disconnect the touchpad ribbon from the motherboard, and remove top cover.
    • Remove the keyboard.
  4. HP Chromebook 11A G8 EE Speaker Replacement, Speaker: passo 4, imagem 1 %32 HP Chromebook 11A G8 EE Speaker Replacement, Speaker: passo 4, imagem 2 %32 HP Chromebook 11A G8 EE Speaker Replacement, Speaker: passo 4, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using the tweezers, carefully disconnect the battery cable from the motherboard.
    • Use the Phillips #0 screwdriver, remove the four 3.5 mm screws that secure the battery cover to the battery.
    • Using the tweezers, carefully remove the battery cover.
  5. HP Chromebook 11A G8 EE Speaker Replacement: passo 5, imagem 1 %32 HP Chromebook 11A G8 EE Speaker Replacement: passo 5, imagem 2 %32 HP Chromebook 11A G8 EE Speaker Replacement: passo 5, imagem 3 %32
    • Using the Phillips #1 screwdriver, remove the 3.5 mm screw that secures the speaker to the frame.
    • Peel back the clear sheet.
    • Using the tweezers, carefully disconnect the speaker cable from the motherboard.
  6. HP Chromebook 11A G8 EE Speaker Replacement: passo 6, imagem 1 %32 HP Chromebook 11A G8 EE Speaker Replacement: passo 6, imagem 2 %32
    • Remove the speaker cable from the routing channel on the keyboard.
    • Using your hands, carefully lift the speakers out of the alignment pins, and remove.
Conclusão
Ella Portwood
Membro desde: 09/03/21
684 Reputação
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 25
Duração total: 338
