Ir para o conteúdo principal
HP Chromebook 11-v011dx Screen Replacement
O que você precisa
  1. HP Chromebook 11-v011dx Screen  Replacement, Key Board: passo 1, imagem 1 %32 HP Chromebook 11-v011dx Screen  Replacement, Key Board: passo 1, imagem 2 %32 HP Chromebook 11-v011dx Screen  Replacement, Key Board: passo 1, imagem 3 %32
    • Wedge the spudger between one of the black rubber caps on each of the four corners on the bottom of the HP Chromebook 11-v011dx.
    • Lift up the black rubber cap until it is completely removed.
    • Repeat this until all four of the black rubber caps are removed.
    Pergunte ao FixBot
    Comentar
  2. HP Chromebook 11-v011dx Screen  Replacement: passo 2, imagem 1 %32 HP Chromebook 11-v011dx Screen  Replacement: passo 2, imagem 2 %32
    • Locate the two smaller black rubber caps on the top corners of the HP ChromeBook 11-v011dx. Wedge the spudger between one of them.
    • Lift up the small black rubber cap until it is completely off.
    • Repeat this step one more time to remove the other small black rubber cap on the other side.
    Pergunte ao FixBot
    Comentar
  3. HP Chromebook 11-v011dx Screen  Replacement: passo 3, imagem 1 %32 HP Chromebook 11-v011dx Screen  Replacement: passo 3, imagem 2 %32
    • Locate the eleven screws on the bottom the HP ChromeBook. Six are located under the larger black rubber caps and the others are in different locations.
    • Use a Phillips #0 screwdriver to remove eleven 1.3mm screws.
    Pergunte ao FixBot
    Comentar
  4. HP Chromebook 11-v011dx Screen  Replacement: passo 4, imagem 1 %32 HP Chromebook 11-v011dx Screen  Replacement: passo 4, imagem 2 %32 HP Chromebook 11-v011dx Screen  Replacement: passo 4, imagem 3 %32
    • Make sure to do steps 1-3 or it will be impossible to lift up the key board and you may also do damage to the hardware.
    • Wedge the spudger between the key board and the bottom panel, carefully go around the keyboards edges gently.
    • Lift the spudger a little in the front of the keyboard until the key board lifts up.
    • With your hands, slowly and carefully lift the key board up.
    Pergunte ao FixBot
    Comentar
  5. HP Chromebook 11-v011dx Screen  Replacement: passo 5, imagem 1 %32
    • Locate the black tab that holds a wire in place that keeps the keyboard connected to the mother board.
    • Slowly unplug this wire that connects to the key board.
    Pergunte ao FixBot
    Comentar
  6. HP Chromebook 11-v011dx Screen  Replacement, Screen: passo 6, imagem 1 %32 HP Chromebook 11-v011dx Screen  Replacement, Screen: passo 6, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the 1.3 mm screw that holds the wireless card.
    Pergunte ao FixBot
    Comentar
  7. HP Chromebook 11-v011dx Screen  Replacement: passo 7, imagem 1 %32 HP Chromebook 11-v011dx Screen  Replacement: passo 7, imagem 2 %32
    • Remove the wireless card from the motherboard with your own hand.
    Pergunte ao FixBot
    Comentar
  8. HP Chromebook 11-v011dx Screen  Replacement: passo 8, imagem 1 %32 HP Chromebook 11-v011dx Screen  Replacement: passo 8, imagem 2 %32
    • Find the wire that connects the screen to the motherboard.
    • Lift black tab that holds the wire in place.
    • Remove the wire.
    Pergunte ao FixBot
    Comentar
  9. HP Chromebook 11-v011dx Screen  Replacement: passo 9, imagem 1 %32 HP Chromebook 11-v011dx Screen  Replacement: passo 9, imagem 2 %32
    • Find the display cable that connects the screen to the motherboard.
    • Lift black tab that holds the display cable in place.
    • Remove display cable.
    Pergunte ao FixBot
    Comentar
  10. HP Chromebook 11-v011dx Screen  Replacement: passo 10, imagem 1 %32 HP Chromebook 11-v011dx Screen  Replacement: passo 10, imagem 2 %32 HP Chromebook 11-v011dx Screen  Replacement: passo 10, imagem 3 %32
    • Use a Phillips #0 screwdriver to remove the four 1.3mm screws that hold the screen in place.
    • Two screws are on the left of the laptop and two are on the right of the laptop.
    Pergunte ao FixBot
    Comentar
  11. HP Chromebook 11-v011dx Screen  Replacement: passo 11, imagem 1 %32 HP Chromebook 11-v011dx Screen  Replacement: passo 11, imagem 2 %32
    • Be careful when removing the screen so it doesn't get caught on any wires.
    • Remove the screen from the laptop.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Kyle DeMello
Membro desde: 10/20/17
542 Reputação
Autoria de 5 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Ao todo: 1,119
