Introdução
This guide should be used if the front-facing camera is malfunctioning, cracked, or has other damage.
O que você precisa
Using a Torx T4 screwdriver, remove the four 5 mm screws on the back panel.
Place the tip of your spudger under the edge of the press fit connector, and pry the connector straight up from its socket.
