Ir para o conteúdo principal
HP 7 Plus 1302 Camera Replacement
O que você precisa
  1. HP 7 Plus 1302 Camera Replacement, Back Cover: passo 1, imagem 1 %32
    • Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
    • Device should be turned off and unplugged before starting the replacements.
  2. HP 7 Plus 1302 Camera Replacement: passo 2, imagem 1 %32 HP 7 Plus 1302 Camera Replacement: passo 2, imagem 2 %32
    • Use the plastic opening tool to push in between the front and the back of the tablet.
    • Slide the plastic opening tool around all 4 sides of the tablet to separate the back cover.
    • Be careful when you are trying to remove the back as it can damage the screen if you force it too much.
  3. HP 7 Plus 1302 Camera Replacement: passo 3, imagem 1 %32 HP 7 Plus 1302 Camera Replacement: passo 3, imagem 2 %32
    • Continue sliding the plastic opening tool around the tablet until all 4 sides are separated from each other.
    • Remove the back cover.
  4. HP 7 Plus 1302 Camera Replacement, Front and Rear Facing Cameras: passo 4, imagem 1 %32
    • The cameras are connected together via a small ribbon cable with one electrical connection in between them.
    • Locate the small grey connector near the top of the device. Using the Spudger tool, gently pull it away from the device until it releases its connection.
    • This will come out very easily so don't use much force.
  5. HP 7 Plus 1302 Camera Replacement: passo 5, imagem 1 %32 HP 7 Plus 1302 Camera Replacement: passo 5, imagem 2 %32
    • Next move to front facing camera. Using the plastic spudger, push the small tabs out of the way while lightly pulling up on the camera.
    • There is a tab on either side of the camera that must both be released.
    • Then gently pull the camera up and away from the device.
  6. HP 7 Plus 1302 Camera Replacement: passo 6, imagem 1 %32
    Ferramenta utilizada neste passo:
    • The rear facing camera is held down with double sided tape.
    • Using the tweezers, gently pry the rear facing camera up out of its socket.
  7. HP 7 Plus 1302 Camera Replacement: passo 7, imagem 1 %32
    • Lift the camera assembly away from the device to remove it.
Conclusão
Uma outra pessoa concluiu este guia.
Erik Hegg
Membro desde: 07/09/15
236 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 1-2, Renguette SU 2015 Membro de IUPUI, Team 1-2, Renguette SU 2015
IUPUI-RENGUETTE-SU15S1G2
5 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 11
Ao todo: 357
