Ir para o conteúdo principal
HP 7 Plus 1302 Back Cover Replacement
O que você precisa
  1. HP 7 Plus 1302 Back Cover Replacement, Back Cover: passo 1, imagem 1 %32
    • Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
    • Device should be turned off and unplugged before starting the replacements.
  2. HP 7 Plus 1302 Back Cover Replacement: passo 2, imagem 1 %32 HP 7 Plus 1302 Back Cover Replacement: passo 2, imagem 2 %32
    • Use the plastic opening tool to push in between the front and the back of the tablet.
    • Slide the plastic opening tool around all 4 sides of the tablet to separate the back cover.
    • Be careful when you are trying to remove the back as it can damage the screen if you force it too much.
  3. HP 7 Plus 1302 Back Cover Replacement: passo 3, imagem 1 %32 HP 7 Plus 1302 Back Cover Replacement: passo 3, imagem 2 %32
    • Continue sliding the plastic opening tool around the tablet until all 4 sides are separated from each other.
    • Remove the back cover.
Conclusão
Marquies
Membro desde: 07/07/15
245 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 1-2, Renguette SU 2015 Membro de IUPUI, Team 1-2, Renguette SU 2015
IUPUI-RENGUETTE-SU15S1G2
5 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 8
Últimos 30 dias: 29
Ao todo: 1,199
