Ir para o conteúdo principal
HP 17-x173dx Optical Disk Drive Replacement
O que você precisa
  1. HP 17-x173dx Optical Disk Drive Replacement, Optical Disk Drive: passo 1, imagem 1 %32
    • Start by placing the laptop with its bottom facing up.
    • Using the Phillips #0 screwdriver, remove the single 7 mm screw that holds the disk drive in place.
  2. HP 17-x173dx Optical Disk Drive Replacement: passo 2, imagem 1 %32 HP 17-x173dx Optical Disk Drive Replacement: passo 2, imagem 2 %32
    • Use a spudger or thin item to apply outward pressure between the disk drive opening and the device to remove the optical disk drive. You may be able to remove it using your fingernail.
Conclusão
Insert new optical drive. To reassemble your device, follow these instructions in reverse order.
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 234
