Ir para o conteúdo principal
HP 17-bs049dx RAM Replacement
O que você precisa
    1. HP 17-bs049dx RAM Replacement, Battery: passo 1, imagem 1 %32
      • To remove the battery, simply push the tabs towards each other.
      • The battery will come out with force, be sure to keep anything fragile away from the laptop during this process.
      Pergunte ao FixBot
      Comentar
    1. HP 17-bs049dx RAM Replacement, Back Panel: passo 2, imagem 1 %32
      • Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
      • Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
      • Rubber tabs will require force to access screws.
      Pergunte ao FixBot
      Comentar
    2. HP 17-bs049dx RAM Replacement: passo 3, imagem 1 %32
      • Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
      Pergunte ao FixBot
      Comentar
    3. HP 17-bs049dx RAM Replacement: passo 4, imagem 1 %32 HP 17-bs049dx RAM Replacement: passo 4, imagem 2 %32
      • Pull outwards on the disk reader to remove from main frame.
      • This removal will require force.
      • All screws must be removed before removing disk reader.
      Pergunte ao FixBot
      Comentar
    4. HP 17-bs049dx RAM Replacement: passo 5, imagem 1 %32
      • Lift back panel to access internal components.
      • You will need to use force to pry it open.
      Pergunte ao FixBot
      Comentar
    1. HP 17-bs049dx RAM Replacement, RAM: passo 6, imagem 1 %32 HP 17-bs049dx RAM Replacement, RAM: passo 6, imagem 2 %32
      • To take off the RAM, pull out the circled taps in the direction of the arrows on the pictures.
      • You will have to gently force it out to avoid breaking it.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 26
Ao todo: 1,134
