Ir para o conteúdo principal
HP 15-g010dx Button Board Replacement
O que você precisa
  1. HP 15-g010dx Button Board Replacement, Battery: passo 1, imagem 1 %32
    • Slide the latch towards the center of the laptop so the unlock emblem appears.
    Pergunte ao FixBot
    Comentar
  2. HP 15-g010dx Button Board Replacement: passo 2, imagem 1 %32
    • Place your finger on the left latch and slide it towards the center of the laptop.
    Pergunte ao FixBot
    Comentar
  3. HP 15-g010dx Button Board Replacement: passo 3, imagem 1 %32
    • Pull on the battery to remove.
    Pergunte ao FixBot
    Comentar
  4. HP 15-g010dx Button Board Replacement, Keyboard: passo 4, imagem 1 %32
    • Remove the two 5 mm screws with the Phillips #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  5. HP 15-g010dx Button Board Replacement: passo 5, imagem 1 %32
    • Using either a credit card or flat spudger, wedge it between the palm rest and the keyboard.
    Pergunte ao FixBot
    Comentar
  6. HP 15-g010dx Button Board Replacement: passo 6, imagem 1 %32
    • Using the tool of your choice, gently pry up on the top of the keyboard.
    Pergunte ao FixBot
    Comentar
  7. HP 15-g010dx Button Board Replacement: passo 7, imagem 1 %32
    • Release the top of the keyboard.
    Pergunte ao FixBot
    Comentar
  8. HP 15-g010dx Button Board Replacement: passo 8, imagem 1 %32
    • Remove the ZIF connector that connects the laptop to the keyboard cable.
    Pergunte ao FixBot
    Comentar
  9. HP 15-g010dx Button Board Replacement, Button Board: passo 9, imagem 1 %32
    • Using a Phillips #00 screwdriver, remove all the 5 millimeter screws located on the bottom of the laptop.
    Pergunte ao FixBot
    Comentar
  10. HP 15-g010dx Button Board Replacement: passo 10, imagem 1 %32
    • Using the spudger, remove the two rubber feet that are located near the battery.
    Pergunte ao FixBot
    Comentar
  11. HP 15-g010dx Button Board Replacement: passo 11, imagem 1 %32
    • Now remove the two Phillips screws that are located below the rubber feet.
    Pergunte ao FixBot
    Comentar
  12. HP 15-g010dx Button Board Replacement: passo 12, imagem 1 %32 HP 15-g010dx Button Board Replacement: passo 12, imagem 2 %32 HP 15-g010dx Button Board Replacement: passo 12, imagem 3 %32
    • Remove the optical drive by pulling it out by hand.
    Pergunte ao FixBot
    Comentar
  13. HP 15-g010dx Button Board Replacement: passo 13, imagem 1 %32
    • Remove the two Phillips screws inside the optical drive housing.
    Pergunte ao FixBot
    Comentar
  14. HP 15-g010dx Button Board Replacement: passo 14, imagem 1 %32
    • Disconnect the power button ribbon cable by lifting the connector.
    Pergunte ao FixBot
    Comentar
  15. HP 15-g010dx Button Board Replacement: passo 15, imagem 1 %32
    • Now disconnect the touch pad ribbon cable by lifting the connector.
    Pergunte ao FixBot
    Comentar
  16. HP 15-g010dx Button Board Replacement: passo 16, imagem 1 %32 HP 15-g010dx Button Board Replacement: passo 16, imagem 2 %32 HP 15-g010dx Button Board Replacement: passo 16, imagem 3 %32
    • Remove the screws indicated by an arrow stamped into the metal.
    Pergunte ao FixBot
    Comentar
  17. HP 15-g010dx Button Board Replacement: passo 17, imagem 1 %32
    • Insert the spudger between the palmrest and the laptop body.
    Pergunte ao FixBot
    Comentar
  18. HP 15-g010dx Button Board Replacement: passo 18, imagem 1 %32
    • Lift up on palm rest, while working the spudger around the perimeter.
    Pergunte ao FixBot
    Comentar
  19. HP 15-g010dx Button Board Replacement: passo 19, imagem 1 %32 HP 15-g010dx Button Board Replacement: passo 19, imagem 2 %32
    • Remove palm rest and flip it over.
    Pergunte ao FixBot
    Comentar
  20. HP 15-g010dx Button Board Replacement: passo 20, imagem 1 %32 HP 15-g010dx Button Board Replacement: passo 20, imagem 2 %32
    • Release the cable connected to the button board.
    Pergunte ao FixBot
    Comentar
  21. HP 15-g010dx Button Board Replacement: passo 21, imagem 1 %32 HP 15-g010dx Button Board Replacement: passo 21, imagem 2 %32
    • Remove the two Phillips screws securing the button board.
    Pergunte ao FixBot
    Comentar
  22. HP 15-g010dx Button Board Replacement: passo 22, imagem 1 %32
    • Remove button board.
    Pergunte ao FixBot
    Comentar
Linha de Chegada
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 31
Ao todo: 692
