Ir para o conteúdo principal
HP 15-dy2702dx Keyboard Replacement
O que você precisa
  1. HP 15-dy2702dx Keyboard Replacement, Lower Case: passo 1, imagem 1 %32
    • Remove both of the rubber strips to uncover the hidden screws.
    • You can use a prying tool to help lift an end.
    Pergunte ao FixBot
    Comentar
  2. HP 15-dy2702dx Keyboard Replacement: passo 2, imagem 1 %32
    • Unscrew all 8 Phillips #1 screws on the bottom panel:
    • Two M2.5x6
    • Six M2x6
    Pergunte ao FixBot
    Comentar
  3. HP 15-dy2702dx Keyboard Replacement: passo 3, imagem 1 %32 HP 15-dy2702dx Keyboard Replacement: passo 3, imagem 2 %32
    • Flip the laptop over and open the lid.
    • Separate the bottom panel from the main body by using the iFixit opening tool.
    • Ensure that the bottom panel is completely separated along the edges.
    Pergunte ao FixBot
    Comentar
  4. HP 15-dy2702dx Keyboard Replacement: passo 4, imagem 1 %32 HP 15-dy2702dx Keyboard Replacement: passo 4, imagem 2 %32
    • If you can lift the laptop like shown in the first picture, the bottom panel is nearly separated.
    • Close the laptop to allow the back edges to fully separate
    Pergunte ao FixBot
    Comentar
  5. HP 15-dy2702dx Keyboard Replacement: passo 5, imagem 1 %32 HP 15-dy2702dx Keyboard Replacement: passo 5, imagem 2 %32 HP 15-dy2702dx Keyboard Replacement: passo 5, imagem 3 %32
    • Flip the laptop over and carefully remove the lower case.
    Pergunte ao FixBot
    Comentar
  6. HP 15-dy2702dx Keyboard Replacement, Battery: passo 6, imagem 1 %32 HP 15-dy2702dx Keyboard Replacement, Battery: passo 6, imagem 2 %32
    • Remove the five M2x6 screws that secure the battery with a Phillips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  7. HP 15-dy2702dx Keyboard Replacement: passo 7, imagem 1 %32 HP 15-dy2702dx Keyboard Replacement: passo 7, imagem 2 %32 HP 15-dy2702dx Keyboard Replacement: passo 7, imagem 3 %32
    • Grab the sides of the battery and gently pull the battery until it disconnects from the connector on motherboard.
    • Lift the battery up and out.
    Pergunte ao FixBot
    Comentar
  8. HP 15-dy2702dx Keyboard Replacement, Trackpad: passo 8, imagem 1 %32
    • Find the trackpad.
    Pergunte ao FixBot
    Comentar
  9. HP 15-dy2702dx Keyboard Replacement: passo 9, imagem 1 %32 HP 15-dy2702dx Keyboard Replacement: passo 9, imagem 2 %32 HP 15-dy2702dx Keyboard Replacement: passo 9, imagem 3 %32
    • Unscrew the two M2x6 Phillips #1 screws securing the trackpad.
    Pergunte ao FixBot
    Comentar
  10. HP 15-dy2702dx Keyboard Replacement: passo 10, imagem 1 %32 HP 15-dy2702dx Keyboard Replacement: passo 10, imagem 2 %32
    • Remove the metal bracket.
    Pergunte ao FixBot
    Comentar
  11. HP 15-dy2702dx Keyboard Replacement: passo 11, imagem 1 %32 HP 15-dy2702dx Keyboard Replacement: passo 11, imagem 2 %32 HP 15-dy2702dx Keyboard Replacement: passo 11, imagem 3 %32
    • Lift the black ribbon covering the screws.
    • Unscrew the top three M2x3 Phillips #0 screws.
    Pergunte ao FixBot
    Comentar
  12. HP 15-dy2702dx Keyboard Replacement: passo 12, imagem 1 %32 HP 15-dy2702dx Keyboard Replacement: passo 12, imagem 2 %32 HP 15-dy2702dx Keyboard Replacement: passo 12, imagem 3 %32
    • Flip up the locking flap holding the trackpad ribbon in place.
    • Pull the ribbon straight out of its socket.
    Pergunte ao FixBot
    Comentar
  13. HP 15-dy2702dx Keyboard Replacement: passo 13, imagem 1 %32 HP 15-dy2702dx Keyboard Replacement: passo 13, imagem 2 %32
    • Peel back the sticky black strip holding the trackpad in place.
    Pergunte ao FixBot
    Comentar
  14. HP 15-dy2702dx Keyboard Replacement: passo 14, imagem 1 %32 HP 15-dy2702dx Keyboard Replacement: passo 14, imagem 2 %32
    • Remove the trackpad from the laptop.
    Pergunte ao FixBot
    Comentar
  15. HP 15-dy2702dx Keyboard Replacement, SSD: passo 15, imagem 1 %32 HP 15-dy2702dx Keyboard Replacement, SSD: passo 15, imagem 2 %32 HP 15-dy2702dx Keyboard Replacement, SSD: passo 15, imagem 3 %32
    • Locate the storage drive.
    • Unscrew the single screw holding the drive in place.
    • The screw is a M2x3 mm Phillips #1 head screw.
    Pergunte ao FixBot
    Comentar
  16. HP 15-dy2702dx Keyboard Replacement: passo 16, imagem 1 %32 HP 15-dy2702dx Keyboard Replacement: passo 16, imagem 2 %32 HP 15-dy2702dx Keyboard Replacement: passo 16, imagem 3 %32
    • Grab the drive by its side and gently pull it out.
    Pergunte ao FixBot
    Comentar
  17. HP 15-dy2702dx Keyboard Replacement, Fan: passo 17, imagem 1 %32 HP 15-dy2702dx Keyboard Replacement, Fan: passo 17, imagem 2 %32 HP 15-dy2702dx Keyboard Replacement, Fan: passo 17, imagem 3 %32
    • Use a Phillips #1 screwdriver to unscrew the three screws that secure the fan.
    • These screws sizes are M2x6.
    Pergunte ao FixBot
    Comentar
  18. HP 15-dy2702dx Keyboard Replacement: passo 18, imagem 1 %32
    • Grip the cord that connects the fan to the motherboard and gently pull out to disconnect the cable from the connector.
    • Alternatively, we recommend using a tool to push the connector out of its socket to avoid damaging the wires.
    Pergunte ao FixBot
    Comentar
  19. HP 15-dy2702dx Keyboard Replacement: passo 19, imagem 1 %32 HP 15-dy2702dx Keyboard Replacement: passo 19, imagem 2 %32
    • Gently lift the fan to remove it from the case.
    Pergunte ao FixBot
    Comentar
  20. HP 15-dy2702dx Keyboard Replacement, Keyboard Assembly: passo 20, imagem 1 %32 HP 15-dy2702dx Keyboard Replacement, Keyboard Assembly: passo 20, imagem 2 %32 HP 15-dy2702dx Keyboard Replacement, Keyboard Assembly: passo 20, imagem 3 %32
    • Disconnect all the ribbon cables from the motherboard.
    • Ensure to flip up the locking flaps before attempting to pull the ribbon out.
    Pergunte ao FixBot
    Comentar
  21. HP 15-dy2702dx Keyboard Replacement: passo 21, imagem 1 %32 HP 15-dy2702dx Keyboard Replacement: passo 21, imagem 2 %32
    • Continue disconnecting the ribbon cables.
    Pergunte ao FixBot
    Comentar
  22. HP 15-dy2702dx Keyboard Replacement: passo 22, imagem 1 %32 HP 15-dy2702dx Keyboard Replacement: passo 22, imagem 2 %32
    • Continue disconnecting the remaining ribbons.
    Pergunte ao FixBot
    Comentar
  23. HP 15-dy2702dx Keyboard Replacement: passo 23, imagem 1 %32 HP 15-dy2702dx Keyboard Replacement: passo 23, imagem 2 %32
    • Disconnect the connector.
    Pergunte ao FixBot
    Comentar
  24. HP 15-dy2702dx Keyboard Replacement: passo 24, imagem 1 %32 HP 15-dy2702dx Keyboard Replacement: passo 24, imagem 2 %32 HP 15-dy2702dx Keyboard Replacement: passo 24, imagem 3 %32
    • Peel off the black sticker covering the silver connectors near the top of the motherboard.
    • Remove the two silver colored round connector from the motherboard by pulling them up.
    • The connector should have a tag on them with number 1 and 2 on them.
    Pergunte ao FixBot
    Comentar
  25. HP 15-dy2702dx Keyboard Replacement: passo 25, imagem 1 %32 HP 15-dy2702dx Keyboard Replacement: passo 25, imagem 2 %32
    • Pull up on the last connector on the motherboard next to the connectors removed in the previous step.
    Pergunte ao FixBot
    Comentar
  26. HP 15-dy2702dx Keyboard Replacement: passo 26, imagem 1 %32 HP 15-dy2702dx Keyboard Replacement: passo 26, imagem 2 %32 HP 15-dy2702dx Keyboard Replacement: passo 26, imagem 3 %32
    • Unscrew all M2x3 Phillips #1 screws holding the motherboard in place.
    Pergunte ao FixBot
    Comentar
  27. HP 15-dy2702dx Keyboard Replacement: passo 27, imagem 1 %32 HP 15-dy2702dx Keyboard Replacement: passo 27, imagem 2 %32
    • Remove the motherboard from the case.
    Pergunte ao FixBot
    Comentar
  28. HP 15-dy2702dx Keyboard Replacement: passo 28, imagem 1 %32 HP 15-dy2702dx Keyboard Replacement: passo 28, imagem 2 %32
    • Unscrew the two M2x3 Phillips #1 screws.
    • Remove the I/O board from the case.
    Pergunte ao FixBot
    Comentar
  29. HP 15-dy2702dx Keyboard Replacement: passo 29, imagem 1 %32 HP 15-dy2702dx Keyboard Replacement: passo 29, imagem 2 %32 HP 15-dy2702dx Keyboard Replacement: passo 29, imagem 3 %32
    • Unscrew the three M2x6 Phillips #1 screws from the left metal hinge.
    • Lift the hinge.
    Pergunte ao FixBot
    Comentar
  30. HP 15-dy2702dx Keyboard Replacement: passo 30, imagem 1 %32 HP 15-dy2702dx Keyboard Replacement: passo 30, imagem 2 %32
    • Unscrew the two Phillips #1 screws.
    • One is on the left side near where the fan was removed.
    • The other is near the right laptop metal hinge.
    Pergunte ao FixBot
    Comentar
  31. HP 15-dy2702dx Keyboard Replacement: passo 31, imagem 1 %32 HP 15-dy2702dx Keyboard Replacement: passo 31, imagem 2 %32
    • Remove the black boxes from the case.
    • Disconnect the power cable (white cable with a black flag at the end).
    • The black boxes is still connected to the case through a black wire, do not attempt to remove the wire.
    Pergunte ao FixBot
    Comentar
  32. HP 15-dy2702dx Keyboard Replacement: passo 32, imagem 1 %32 HP 15-dy2702dx Keyboard Replacement: passo 32, imagem 2 %32 HP 15-dy2702dx Keyboard Replacement: passo 32, imagem 3 %32
    • Unscrew the three Philips head #1 screws on the right-side metal hinge.
    • Lift the hinge.
    Pergunte ao FixBot
    Comentar
  33. HP 15-dy2702dx Keyboard Replacement: passo 33, imagem 1 %32
    • Remove the DC in jack from the case by pulling it straight up.
    Pergunte ao FixBot
    Comentar
  34. HP 15-dy2702dx Keyboard Replacement: passo 34, imagem 1 %32 HP 15-dy2702dx Keyboard Replacement: passo 34, imagem 2 %32 HP 15-dy2702dx Keyboard Replacement: passo 34, imagem 3 %32
    • Remove the keyboard from the laptop.
    • The keyboard is a type where it is directly integrated into the frame so you will need to replace the whole frame.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Zander Herbold
Membro desde: 09/05/23
700 Reputação
Autoria de 4 guias
Equipe
Gateway, Team 1-4, Pee Fall 2023 Membro de Gateway, Team 1-4, Pee Fall 2023
GCC-PEE-F23S1G4
4 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 17
Últimos 30 dias: 111
Ao todo: 1,661
