Ir para o conteúdo principal
HP 15-dy2702dx Fan Replacement
O que você precisa
  1. HP 15-dy2702dx Fan Replacement, Lower Case: passo 1, imagem 1 %32
    • Remove both of the rubber strips to uncover the hidden screws.
    • You can use a prying tool to help lift an end.
    Pergunte ao FixBot
    Comentar
  2. HP 15-dy2702dx Fan Replacement: passo 2, imagem 1 %32
    • Unscrew all 8 Phillips #1 screws on the bottom panel:
    • Two M2.5x6
    • Six M2x6
    Pergunte ao FixBot
    Comentar
  3. HP 15-dy2702dx Fan Replacement: passo 3, imagem 1 %32 HP 15-dy2702dx Fan Replacement: passo 3, imagem 2 %32
    • Flip the laptop over and open the lid.
    • Separate the bottom panel from the main body by using the iFixit opening tool.
    • Ensure that the bottom panel is completely separated along the edges.
    Pergunte ao FixBot
    Comentar
  4. HP 15-dy2702dx Fan Replacement: passo 4, imagem 1 %32 HP 15-dy2702dx Fan Replacement: passo 4, imagem 2 %32
    • If you can lift the laptop like shown in the first picture, the bottom panel is nearly separated.
    • Close the laptop to allow the back edges to fully separate
    Pergunte ao FixBot
    Comentar
  5. HP 15-dy2702dx Fan Replacement: passo 5, imagem 1 %32 HP 15-dy2702dx Fan Replacement: passo 5, imagem 2 %32 HP 15-dy2702dx Fan Replacement: passo 5, imagem 3 %32
    • Flip the laptop over and carefully remove the lower case.
    Pergunte ao FixBot
    Comentar
  6. HP 15-dy2702dx Fan Replacement, Fan: passo 6, imagem 1 %32 HP 15-dy2702dx Fan Replacement, Fan: passo 6, imagem 2 %32 HP 15-dy2702dx Fan Replacement, Fan: passo 6, imagem 3 %32
    • Use a Phillips #1 screwdriver to unscrew the three screws that secure the fan.
    • These screws sizes are M2x6.
    Pergunte ao FixBot
    Comentar
  7. HP 15-dy2702dx Fan Replacement: passo 7, imagem 1 %32
    • Grip the cord that connects the fan to the motherboard and gently pull out to disconnect the cable from the connector.
    • Alternatively, we recommend using a tool to push the connector out of its socket to avoid damaging the wires.
    Pergunte ao FixBot
    Comentar
  8. HP 15-dy2702dx Fan Replacement: passo 8, imagem 1 %32 HP 15-dy2702dx Fan Replacement: passo 8, imagem 2 %32
    • Gently lift the fan to remove it from the case.
    Pergunte ao FixBot
    Comentar
Conclusão
September Oo
Membro desde: 09/07/23
418 Reputação
Autoria de 4 guias
Equipe
Gateway, Team 1-4, Pee Fall 2023 Membro de Gateway, Team 1-4, Pee Fall 2023
GCC-PEE-F23S1G4
4 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 49
Ao todo: 762
