Ir para o conteúdo principal
HP 15-dy Rubber Feet Replacement
O que você precisa
  1. HP 15-dy Rubber Feet Replacement, Flip your laptop over: passo 1, imagem 1 %32
    • Flip your laptop over so the rubber feet are facing up.
  2. HP 15-dy Rubber Feet Replacement, Peel up an end of the front foot: passo 2, imagem 1 %32 HP 15-dy Rubber Feet Replacement, Peel up an end of the front foot: passo 2, imagem 2 %32 HP 15-dy Rubber Feet Replacement, Peel up an end of the front foot: passo 2, imagem 3 %32
    • The rubber feet cover a total of six back cover screws.
    • Use an opening pick to peel up an end of the front rubber foot until you can grip it with your fingers.
    • Make sure both the foot and its adhesive peel up together, as they need to be removed as one piece.
  3. HP 15-dy Rubber Feet Replacement, Remove the front foot: passo 3, imagem 1 %32 HP 15-dy Rubber Feet Replacement, Remove the front foot: passo 3, imagem 2 %32 HP 15-dy Rubber Feet Replacement, Remove the front foot: passo 3, imagem 3 %32
    • Peel the front foot away from the back cover and remove it.
  4. HP 15-dy Rubber Feet Replacement, Remove the rear foot: passo 4, imagem 1 %32 HP 15-dy Rubber Feet Replacement, Remove the rear foot: passo 4, imagem 2 %32 HP 15-dy Rubber Feet Replacement, Remove the rear foot: passo 4, imagem 3 %32
    • Use an opening pick to peel up an end of the rear rubber foot until you can grip it with your fingers.
    • Peel the rear foot away from the back cover and remove it.
  5. HP 15-dy Rubber Feet Replacement, Reassembly information: passo 5, imagem 1 %32 HP 15-dy Rubber Feet Replacement, Reassembly information: passo 5, imagem 2 %32 HP 15-dy Rubber Feet Replacement, Reassembly information: passo 5, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Tesa 61395 Tape
    $5.99
    Comprar
    • Note that the rubber feet are different:
    • The rear foot is thicker, with a deeper recess.
    • The front foot is thinner, with a shallower recess.
    • During reassembly:
    • If you're reusing the rubber feet, the leftover adhesive should be tacky enough to reuse.
    • If the leftover adhesive isn't sticky enough or your replacement feet didn't come with adhesive, you can use double-sided tape such as Tesa Tape to secure the feet.
    • Make sure the strips of tape aren't wider than 6 mm, otherwise they may not fit.
    • To install a foot, remove its adhesive liner, lay the foot into its matching recess, and press down firmly along the entire length of the foot to secure it.
Conclusão
Spencer Day
Membro desde: 09/14/22
55.203 Reputação
Autoria de 408 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 136
Autoria de 17.430 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 112
Duração total: 1,225
