Ir para o conteúdo principal
HP 15-bs168cl Hard Drive Replacement
O que você precisa
  1. HP 15-bs168cl Hard Drive Replacement, Battery: passo 1, imagem 1 %32 HP 15-bs168cl Hard Drive Replacement, Battery: passo 1, imagem 2 %32
    • Unplug your laptop from its power adapter.
    • Turn the laptop over.
  2. HP 15-bs168cl Hard Drive Replacement: passo 2, imagem 1 %32 HP 15-bs168cl Hard Drive Replacement: passo 2, imagem 2 %32
    • Slide the Battery lock slider to the right until you see the “Unlocked” lock symbol.
  3. HP 15-bs168cl Hard Drive Replacement: passo 3, imagem 1 %32 HP 15-bs168cl Hard Drive Replacement: passo 3, imagem 2 %32
    • Slide the Battery release slider towards the battery while pulling the battery out.
  4. HP 15-bs168cl Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32 HP 15-bs168cl Hard Drive Replacement, Hard Drive: passo 4, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the six 10.5 mm screws visible on the bottom of the laptop.
  5. HP 15-bs168cl Hard Drive Replacement: passo 5, imagem 1 %32 HP 15-bs168cl Hard Drive Replacement: passo 5, imagem 2 %32
    • Carefully peel the four rubber feet off the bottom to reveal the four hidden screws.
    • Use a Phillips #1 screwdriver to remove the four 10.5 mm screws.
  6. HP 15-bs168cl Hard Drive Replacement: passo 6, imagem 1 %32
    • Remove the DVD drive by carefully sliding it out.
  7. HP 15-bs168cl Hard Drive Replacement: passo 7, imagem 1 %32 HP 15-bs168cl Hard Drive Replacement: passo 7, imagem 2 %32 HP 15-bs168cl Hard Drive Replacement: passo 7, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Plastic Cards
    $2.99
    Comprar
    • Flip the laptop over and open the screen.
    • Carefully use a flat plastic card to separate the bottom plastic shell from the main body of the computer. Slowly slide the plastic card around the computer in between the two halves of its casing.
    • Flip the computer back over and remove the bottom plastic shell.
  8. HP 15-bs168cl Hard Drive Replacement: passo 8, imagem 1 %32 HP 15-bs168cl Hard Drive Replacement: passo 8, imagem 2 %32 HP 15-bs168cl Hard Drive Replacement: passo 8, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove the two 3.4 mm screws on the sides.
    • Use a Phillips #0 screwdriver to remove the one 3.3 mm screw at the bottom of the bracket.
  9. HP 15-bs168cl Hard Drive Replacement: passo 9, imagem 1 %32 HP 15-bs168cl Hard Drive Replacement: passo 9, imagem 2 %32
    • Remove the metal bracket holding the hard drive in place.
    • Carefully lift up the hard drive and slide it out of its connector.
Conclusão
5 outras pessoas executaram este guia.
Ian Gascon
Membro desde: 10/15/19
792 Reputação
Autoria de 4 guias
Equipe
Um comentário
Thanks, I would have missed the screws under the rubber feet!
Kenneth Dalton - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 23
Duração total: 1,518
