Introdução
Before replacing the fan on your laptop, follow this troubleshooting guide to make sure it is a hardware issue with your fan. If your fan is making a lot of noise/sounds like it is rattling or your computer is constantly getting very hot, follow this guide to properly remove and replace your fan.
O que você precisa
Use a Phillips #0 screwdriver to remove the six 10.5 mm screws visible on the bottom of the laptop.
Ferramenta utilizada nesse passo:Plastic Cards$2.99
Flip the laptop over and open the screen.
Carefully use a flat plastic card to separate the bottom plastic shell from the main body of the computer. Slowly slide the plastic card around the computer in between the two halves of its casing.
Flip the computer back over and remove the bottom plastic shell.
