Ir para o conteúdo principal
HP 15-bs051od Screen Replacement
O que você precisa
    1. HP 15-bs051od Screen Replacement, RAM: passo 1, imagem 1 %32
      • Start with the laptop face down.
      • Remove the eight 6 mm Phillips head screws securing the lower case.
      Pergunte ao FixBot
      Comentar
    2. HP 15-bs051od Screen Replacement: passo 2, imagem 1 %32 HP 15-bs051od Screen Replacement: passo 2, imagem 2 %32
      • Use the opening tool to pry the lower case away from the body of the laptop.
      • Remove the lower case.
      Pergunte ao FixBot
      Comentar
    3. HP 15-bs051od Screen Replacement: passo 3, imagem 1 %32 HP 15-bs051od Screen Replacement: passo 3, imagem 2 %32 HP 15-bs051od Screen Replacement: passo 3, imagem 3 %32
      • Pull the RAM-retaining arms away from the RAM chip.
      • The RAM chip should slightly "pop" up from it's socket.
      Pergunte ao FixBot
      Comentar
    4. HP 15-bs051od Screen Replacement: passo 4, imagem 1 %32 HP 15-bs051od Screen Replacement: passo 4, imagem 2 %32
      • Pull the RAM chip out of its socket.
      • Our device does not specifically have a second RAM chip, but make sure to remove the second RAM chip below the first RAM chip.
      • Repeat this process for the second RAM chip.
      Pergunte ao FixBot
      Comentar
    1. HP 15-bs051od Screen Replacement, Motherboard: passo 5, imagem 1 %32 HP 15-bs051od Screen Replacement, Motherboard: passo 5, imagem 2 %32 HP 15-bs051od Screen Replacement, Motherboard: passo 5, imagem 3 %32
      • Remove the four (4 mm) Phillips screws on the heatsink.
      • Remove the exhaust by carefully lifting it up.
      Pergunte ao FixBot
      Comentar
    2. HP 15-bs051od Screen Replacement: passo 6, imagem 1 %32
      • Disconnect the connecting cable of the fan and remove the fan.
      Pergunte ao FixBot
      Comentar
    3. HP 15-bs051od Screen Replacement: passo 7, imagem 1 %32 HP 15-bs051od Screen Replacement: passo 7, imagem 2 %32
      • Pull the red, white, black, and blue cable directly out of its port.
      Pergunte ao FixBot
      Comentar
    4. HP 15-bs051od Screen Replacement: passo 8, imagem 1 %32
      • Slide the left speaker out.
      Pergunte ao FixBot
      Comentar
    5. HP 15-bs051od Screen Replacement: passo 9, imagem 1 %32
      • Pull the black and red cable connecting both speakers out of its secure fastening.
      Pergunte ao FixBot
      Comentar
    6. HP 15-bs051od Screen Replacement: passo 10, imagem 1 %32
      • Pull the right speaker out by sliding from left to right.
      Pergunte ao FixBot
      Comentar
    7. HP 15-bs051od Screen Replacement: passo 11, imagem 1 %32 HP 15-bs051od Screen Replacement: passo 11, imagem 2 %32
      • Locate the motherboard.
      • The motherboard is the biggest blue-colored surface located inside the computer.
      • Locate the six ribbon cables.
      Pergunte ao FixBot
      Comentar
    8. HP 15-bs051od Screen Replacement: passo 12, imagem 1 %32 HP 15-bs051od Screen Replacement: passo 12, imagem 2 %32
      • Flip up the ZIF lock bars that keep the six ribbon cables in place.
      • Slide the rest of the ribbon cables out of their fastenings.
      Pergunte ao FixBot
      Comentar
    9. HP 15-bs051od Screen Replacement: passo 13, imagem 1 %32 HP 15-bs051od Screen Replacement: passo 13, imagem 2 %32
      • Remove the four (4 mm) Phillips screws securing the motherboard.
      Pergunte ao FixBot
      Comentar
    10. HP 15-bs051od Screen Replacement: passo 14, imagem 1 %32 HP 15-bs051od Screen Replacement: passo 14, imagem 2 %32
      • Remove the single (4 mm) Phillips screw on the Wi-Fi card.
      • Slide the Wi-Fi card out of its port.
      Pergunte ao FixBot
      Comentar
    11. HP 15-bs051od Screen Replacement: passo 15, imagem 1 %32 HP 15-bs051od Screen Replacement: passo 15, imagem 2 %32
      • Unfasten the connecting cable.
      Pergunte ao FixBot
      Comentar
    12. HP 15-bs051od Screen Replacement: passo 16, imagem 1 %32 HP 15-bs051od Screen Replacement: passo 16, imagem 2 %32
      • Remove the display cable.
      Pergunte ao FixBot
      Comentar
    13. HP 15-bs051od Screen Replacement: passo 17, imagem 1 %32
      • Lift up the motherboard.
      Pergunte ao FixBot
      Comentar
    1. HP 15-bs051od Screen Replacement, Screen: passo 18, imagem 1 %32
      • Remove the following Phillips screws:
      • Five 7 mm screws on the display hinge.
      • One 3 mm screw.
      Pergunte ao FixBot
      Comentar
    2. HP 15-bs051od Screen Replacement: passo 19, imagem 1 %32
      • Partially open the laptop and remove the base.
      Pergunte ao FixBot
      Comentar
    3. HP 15-bs051od Screen Replacement: passo 20, imagem 1 %32 HP 15-bs051od Screen Replacement: passo 20, imagem 2 %32
      • Use the opening tool to carefully separate the screen cover from the screen.
      • Use the opening tool to carefully remove the adhesive screen bezel from around the screen.
      Pergunte ao FixBot
      Comentar
    4. HP 15-bs051od Screen Replacement: passo 21, imagem 1 %32
      • Two 4 mm screws from the top of the screen.
      • Two 4 mm from the bottom of the screen.
      Pergunte ao FixBot
      Comentar
    5. HP 15-bs051od Screen Replacement: passo 22, imagem 1 %32
      • Carefully lift the screen from the display assembly without disconnecting the display cable.
      Pergunte ao FixBot
      Comentar
    6. HP 15-bs051od Screen Replacement: passo 23, imagem 1 %32
      • Remove the display cable from the back of the screen.
      Pergunte ao FixBot
      Comentar
    7. HP 15-bs051od Screen Replacement: passo 24, imagem 1 %32
      • Remove the screen from the display assembly.
      Pergunte ao FixBot
      Comentar
Conclusão
Kaz Furtado
Membro desde: 03/20/23
148 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 6-1, Botvin Spring 2023 Membro de UMass Dartmouth, Team 6-1, Botvin Spring 2023
UMASSD-BOTVIN-S23S6G1
4 Membros
Autoria de 40 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 22
Ao todo: 529
