Ir para o conteúdo principal
HP 15-ay114cy Speakers Replacement
O que você precisa
  1. HP 15-ay114cy Speakers Replacement, Orient the Laptop: passo 1, imagem 1 %32
    • Orient the Laptop so the HP logo is facing the table and the battery tabs are accessible.
    • Ensure the laptop is powered off before moving forward.
  2. HP 15-ay114cy Speakers Replacement, Push out the Battery: passo 2, imagem 1 %32 HP 15-ay114cy Speakers Replacement, Push out the Battery: passo 2, imagem 2 %32
    • Place your index fingers on each of the two battery holder clips.
    • Using your index fingers, push the battery holder clips inwards (towards the center of the laptop).
  3. HP 15-ay114cy Speakers Replacement, Remove the Battery: passo 3, imagem 1 %32 HP 15-ay114cy Speakers Replacement, Remove the Battery: passo 3, imagem 2 %32
    • After the battery clips are pushed in, use either hand to grab hold of the battery.
    • Gently push up to remove the battery.
  4. HP 15-ay114cy Speakers Replacement, Unscrew the Back Cover: passo 4, imagem 1 %32 HP 15-ay114cy Speakers Replacement, Unscrew the Back Cover: passo 4, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the 8 mm Phillips-head screws that are holding on the bottom cover of the Laptop.
  5. HP 15-ay114cy Speakers Replacement, Remove the Disk Drive: passo 5, imagem 1 %32 HP 15-ay114cy Speakers Replacement, Remove the Disk Drive: passo 5, imagem 2 %32
    • Grab a hold of the disk drive and carefully pull it away from the computer.
    • Continue to slide the disk drive out of the laptop until fully removed.
    • Due to the removal of the battery, no power is available to open the disk drive through the use of the eject button.
    • Make sure to pull out the disk drive at a 90 degree angle as demonstrated. Do not attempt to wiggle the drive out of the laptop.
    • There will be resistance when removing the drive. Mishandling may cause broken wires, which could make your disk drive inoperative.
  6. HP 15-ay114cy Speakers Replacement, Remove the Back Cover: passo 6, imagem 1 %32 HP 15-ay114cy Speakers Replacement, Remove the Back Cover: passo 6, imagem 2 %32 HP 15-ay114cy Speakers Replacement, Remove the Back Cover: passo 6, imagem 3 %32
    • Place a plastic opening tool in-between the upper and lower pieces of the bottom cover.
    • Using your hands and the plastic opening tool, gently separate the cover from the frame.
    • Slowly remove the bottom cover from the base of the laptop.
    • Using metal pry tools can damage your device.
  7. HP 15-ay114cy Speakers Replacement, Remove the Speakers: passo 7, imagem 1 %32 HP 15-ay114cy Speakers Replacement, Remove the Speakers: passo 7, imagem 2 %32 HP 15-ay114cy Speakers Replacement, Remove the Speakers: passo 7, imagem 3 %32
    • Using your index finger and thumb, lift the right speaker to remove it from its housing. This will give enough room to pull the wiring harness from the adapter.
    • Follow the connected wire to the harness.
  8. HP 15-ay114cy Speakers Replacement, Insert the Replacement Speakers: passo 8, imagem 1 %32 HP 15-ay114cy Speakers Replacement, Insert the Replacement Speakers: passo 8, imagem 2 %32 HP 15-ay114cy Speakers Replacement, Insert the Replacement Speakers: passo 8, imagem 3 %32
    • Grabbing the base of the wiring harness, use a bit of force to separate the harness from the motherboard adapter.
    • Lift up the old speakers and remove the wiring from the plastic routing tabs.
Conclusão
Bradley Evans
Membro desde: 01/24/20
613 Reputação
Autoria de 5 guias
Equipe
S20S3G#1 Membro de S20S3G#1
Local Repair Groups
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 123
