Ir para o conteúdo principal
HP 15-ay114cy Battery Replacement
  1. HP 15-ay114cy Battery Replacement, Orient the Laptop: passo 1, imagem 1 %32
    • Orient the Laptop so the HP logo is facing the table and the battery tabs are accessible.
    • Ensure the laptop is powered off before moving forward.
  2. HP 15-ay114cy Battery Replacement, Push out the Battery: passo 2, imagem 1 %32 HP 15-ay114cy Battery Replacement, Push out the Battery: passo 2, imagem 2 %32
    • Place your index fingers on each of the two battery holder clips.
    • Using your index fingers, push the battery holder clips inwards (towards the center of the laptop).
  3. HP 15-ay114cy Battery Replacement, Remove the Battery: passo 3, imagem 1 %32 HP 15-ay114cy Battery Replacement, Remove the Battery: passo 3, imagem 2 %32
    • After the battery clips are pushed in, use either hand to grab hold of the battery.
    • Gently push up to remove the battery.
Conclusão
Michael Falanga
Membro desde: 01/24/20
347 Reputação
Autoria de 1 guia
Equipe
S20S3G#1 Membro de S20S3G#1
Local Repair Groups
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 283
