Ir para o conteúdo principal
HP 15-ay078nr Speakers Replacement
O que você precisa
  1. HP 15-ay078nr Speakers Replacement, Battery: passo 1, imagem 1 %32
    • Orient the laptop so that the underside is facing up.
    • Rotate the device so that the CD slot is in the upper left corner.
  2. HP 15-ay078nr Speakers Replacement: passo 2, imagem 1 %32 HP 15-ay078nr Speakers Replacement: passo 2, imagem 2 %32
    • Put your fingers on the battery latch.
  3. HP 15-ay078nr Speakers Replacement: passo 3, imagem 1 %32 HP 15-ay078nr Speakers Replacement: passo 3, imagem 2 %32
    • Using your fingers, push each battery latch simultaneously towards the middle.
    • This releases the battery.
    • Remove the battery from the laptop.
  4. HP 15-ay078nr Speakers Replacement, Back Panel: passo 4, imagem 1 %32 HP 15-ay078nr Speakers Replacement, Back Panel: passo 4, imagem 2 %32
    • Pull off the two rubber feet on the underside of the device.
    • Remove the twelve 9.5 mm screws from the underside of the device using a Phillips #2 screwdriver.
  5. HP 15-ay078nr Speakers Replacement: passo 5, imagem 1 %32
    • Slide an opening pick around the edges between the back panel and the rest of the device to release the plastic retention clips that hold the panel in place.
  6. HP 15-ay078nr Speakers Replacement: passo 6, imagem 1 %32
    • Lift up on the panel to remove it completely from the device.
  7. HP 15-ay078nr Speakers Replacement, Speakers: passo 7, imagem 1 %32 HP 15-ay078nr Speakers Replacement, Speakers: passo 7, imagem 2 %32
    • The speakers are located in the bottom right and left corners of the device.
    • Use the opening pick to pry up the two plastic clip fasteners.
  8. HP 15-ay078nr Speakers Replacement: passo 8, imagem 1 %32
    • Pull the cable speaker cable out of its housing on the motherboard.
Conclusão
Cameron Duffy
Membro desde: 10/25/21
327 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 3-1, Sinclaire Fall 2021 Membro de UMass Dartmouth, Team 3-1, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G1
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Duração total: 155
