Introdução
The optical drive is how your HP 15-ay078nr laptop reads and writes to disks, like CDs or DVDs. This component is useful when playing a movie from a DVD, installing software from a CD, burning music to a CD, etc. The optical drive may need to be replaced if it will not eject disks, or can’t read/write to a disk. If the optical drive will not eject, ensure there is nothing stuck or jammed in the area, which could be preventing the action. If there is nothing noticeably jammed, further troubleshooting information about the optical drive can be found here to determine if it needs to be replaced.
Before you begin replacing the optical drive, make sure the device is powered off.
O que você precisa
Orient the laptop so that the underside is facing up.
Rotate the device so that the CD slot is in the upper left corner.
Pull off the two rubber feet on the underside of the device.
Remove the twelve 9.5 mm screws from the underside of the device using a Phillips #2 screwdriver.
Slide the optical drive outward through the cutout in the device back panel to remove it from the laptop.
