Ir para o conteúdo principal
HP 15-ay052nr Fan Replacement
O que você precisa
    1. HP 15-ay052nr Fan Replacement, Battery: passo 1, imagem 1 %32
      • To protect the device and yourself, make sure your device is completely powered down before disassembling. Disconnect all external devices before starting any tear down process.
      • Turn the device and lay it upside-down on a flat surface so the base of the computer is facing upwards.
      Pergunte ao FixBot
      Comentar
    2. HP 15-ay052nr Fan Replacement: passo 2, imagem 1 %32
      • Identify the two (2) sliding lock mechanisms on either side of the battery and slide them towards the center.
      • The sliders are located at the back of the device on the side where the display hinges are.
      • The slider closest to the optical drive (CD reader) clicks open but the opposite slider has a spring.
      Pergunte ao FixBot
      Comentar
    3. HP 15-ay052nr Fan Replacement: passo 3, imagem 1 %32
      • Pull the battery slightly up and out to remove.
      • If the battery doesn't pop out, the sliders weren't pushed in far enough. Push the sliders towards the center until the battery pops out.
      Pergunte ao FixBot
      Comentar
    1. HP 15-ay052nr Fan Replacement, Bottom Cover: passo 4, imagem 1 %32
      • Remove the rubber feet on the bottom of the device to access all the screws.
      • There are two rubber feet, one on each side of the battery compartment.
      Pergunte ao FixBot
      Comentar
    2. HP 15-ay052nr Fan Replacement: passo 5, imagem 1 %32
      • Unscrew the twelve 9 mm JIS #0 screws on the back of the device.
      • Gently remove the optical drive (CD reader) to more easily separate the base.
      Pergunte ao FixBot
      Comentar
    3. HP 15-ay052nr Fan Replacement: passo 6, imagem 1 %32
      • Unclip the keyboard surface from the base using an iFixit opening tool around the entire border.
      Pergunte ao FixBot
      Comentar
    4. HP 15-ay052nr Fan Replacement: passo 7, imagem 1 %32
      • Separate the base of the computer from the component assembly.
      • The optical drive can be placed in the base where it corresponds to prevent misplacing it.
      Pergunte ao FixBot
      Comentar
    1. HP 15-ay052nr Fan Replacement, Fan: passo 8, imagem 1 %32
      • Remove the two 6.5 mm JIS #0 screws holding the cooling fan to the base.
      • The base is the side by the heatsink, which is made of copper.
      Pergunte ao FixBot
      Comentar
    2. HP 15-ay052nr Fan Replacement: passo 9, imagem 1 %32
      • Unplug the fan cable from the motherboard.
      • The fan can now be removed.
      Pergunte ao FixBot
      Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 21
Ao todo: 772
