Ir para o conteúdo principal
HP 15-R263DX USB Port Replacement
O que você precisa
    1. HP 15-R263DX USB Port Replacement, Battery: passo 1, imagem 1 %32 HP 15-R263DX USB Port Replacement, Battery: passo 1, imagem 2 %32
      • Eject the battery from the computer by sliding the two clips on the bottom of the computer toward the center of the computer.
      • Slide the battery out as shown in the picture.
      Pergunte ao FixBot
      Comentar
    1. HP 15-R263DX USB Port Replacement, Optical Drive: passo 2, imagem 1 %32 HP 15-R263DX USB Port Replacement, Optical Drive: passo 2, imagem 2 %32
      • Using a Phillips #1 screwdriver, remove the small screw next to the disc engraving shown in the picture.
      Pergunte ao FixBot
      Comentar
    2. HP 15-R263DX USB Port Replacement: passo 3, imagem 1 %32
      • Gently slide the optical drive out of the side of the computer.
      Pergunte ao FixBot
      Comentar
    1. HP 15-R263DX USB Port Replacement, HP 15-R263DX Disassembly: passo 4, imagem 1 %32 HP 15-R263DX USB Port Replacement, HP 15-R263DX Disassembly: passo 4, imagem 2 %32
      • Locate the two corner grips on the hinge side of the computer.
      • Using a metal spudger, remove the two corner grips to reveal the screws.
      Pergunte ao FixBot
      Comentar
    2. HP 15-R263DX USB Port Replacement: passo 5, imagem 1 %32
      • Remove the 11 small screws on the bottom of the computer that are shown in the picture.
      Pergunte ao FixBot
      Comentar
    3. HP 15-R263DX USB Port Replacement: passo 6, imagem 1 %32
      • Remove the 2 small screws that are on the bottom side of the disc tray slot.
      • These screws are shorter and wider than the others.
      Pergunte ao FixBot
      Comentar
    4. HP 15-R263DX USB Port Replacement: passo 7, imagem 1 %32 HP 15-R263DX USB Port Replacement: passo 7, imagem 2 %32
      • Once the keyboard is loose, do not immediately pull away from computer. It is attached by the ribbon connector.
      • Using a spudger, pry around the edges of the keyboard until all clips are disengaged and the keyboard is loose from the computer.
      • To disconnect the ribbon connector, flip up the black clip shown in the picture.
      • Gently pull the ribbon until disconnected.
      Pergunte ao FixBot
      Comentar
    5. HP 15-R263DX USB Port Replacement: passo 8, imagem 1 %32 HP 15-R263DX USB Port Replacement: passo 8, imagem 2 %32
      • Disconnect the other two ribbon connectors underneath the keyboard by fliping up the black clips.
      • Remove the 4 small screws shown in the picture.
      Pergunte ao FixBot
      Comentar
    6. HP 15-R263DX USB Port Replacement: passo 9, imagem 1 %32
      • Disengage the face plate clips by prying the case away from around the outer edge of the face plate with a metal wedge.
      • The face plate can then be lifted away from the computer.
      Pergunte ao FixBot
      Comentar
    1. HP 15-R263DX USB Port Replacement, Hard Drive: passo 10, imagem 1 %32
      • Remove the 2 black screws holding the hard drive to the computer frame.
      Pergunte ao FixBot
      Comentar
    2. HP 15-R263DX USB Port Replacement: passo 11, imagem 1 %32 HP 15-R263DX USB Port Replacement: passo 11, imagem 2 %32
      • Gently slide the hard drive away from the motherboard to disconnect it.
      • After it's disconnected, lift the hard drive up to remove it from the computer.
      Pergunte ao FixBot
      Comentar
    1. HP 15-R263DX USB Port Replacement, USB Port: passo 12, imagem 1 %32
      • Remove the single screw holding the USB ports and chip into the computer.
      Pergunte ao FixBot
      Comentar
    2. HP 15-R263DX USB Port Replacement: passo 13, imagem 1 %32
      • Remove the chip by gently pulling it up and then away from the edge of the case.
      Pergunte ao FixBot
      Comentar
    3. HP 15-R263DX USB Port Replacement: passo 14, imagem 1 %32
      • Under the motherboard, disconnect the wire that runs to the USB chip.
      • You may need to pull or wedge the wire up from the case as a section of it is glued down.
      Pergunte ao FixBot
      Comentar
Conclusão
Drake Hort
Membro desde: 03/05/18
487 Reputação
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 24
Ao todo: 816
