Ir para o conteúdo principal
HP 15-R263DX Keyboard Replacement
O que você precisa
  1. HP 15-R263DX Keyboard Replacement, Battery: passo 1, imagem 1 %32 HP 15-R263DX Keyboard Replacement, Battery: passo 1, imagem 2 %32
    • Eject the battery from the computer by sliding the two clips on the bottom of the computer toward the center of the computer.
    • Slide the battery out as shown in the picture.
    Pergunte ao FixBot
    Comentar
  2. HP 15-R263DX Keyboard Replacement, Keyboard: passo 2, imagem 1 %32
    • Once keyboard is loose, do not immediately remove it from the computer. It is attached by a ribbon connector.
    • Using a metal wedge tool, pry up along the top edge of the keyboard until all clips are disengaged and the keyboard is loose from the computer.
    Pergunte ao FixBot
    Comentar
  3. HP 15-R263DX Keyboard Replacement: passo 3, imagem 1 %32
    • To disconnect the ribbon connector, flip up the black clip shown in the picture.
    • Gently pull the ribbon until disconnected.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 18
Ao todo: 681
