Ir para o conteúdo principal
HP 15-R011DX RAM (Random Access Memory) Replacement
O que você precisa
  1. HP 15-R011DX RAM (Random Access Memory) Replacement, Battery: passo 1, imagem 1 %32 HP 15-R011DX RAM (Random Access Memory) Replacement, Battery: passo 1, imagem 2 %32
    • Slide the lock mechanism on the left side of the laptop to the right.
    Pergunte ao FixBot
    Comentar
  2. HP 15-R011DX RAM (Random Access Memory) Replacement: passo 2, imagem 1 %32
    • While holding the right slide mechanism, remove the battery from the laptop.
    • The battery is not pictured here because it is missing from this particular device.
    Pergunte ao FixBot
    Comentar
  3. HP 15-R011DX RAM (Random Access Memory) Replacement, How to Access the Internal Components of an HP 15-R011DX: passo 3, imagem 1 %32 HP 15-R011DX RAM (Random Access Memory) Replacement, How to Access the Internal Components of an HP 15-R011DX: passo 3, imagem 2 %32
    • Flip the laptop over to reveal screw locations.
    • Use a metal spudger to remove the two rear rubber feet. There are screws hidden underneath them.
    Pergunte ao FixBot
    Comentar
  4. HP 15-R011DX RAM (Random Access Memory) Replacement: passo 4, imagem 1 %32 HP 15-R011DX RAM (Random Access Memory) Replacement: passo 4, imagem 2 %32
    • Remove the twelve 5mm Phillips #1 screws on the back of the laptop.
    Pergunte ao FixBot
    Comentar
  5. HP 15-R011DX RAM (Random Access Memory) Replacement: passo 5, imagem 1 %32 HP 15-R011DX RAM (Random Access Memory) Replacement: passo 5, imagem 2 %32
    • Remove the DVD drive from the laptop.
    • Remove the two 3 mm Phillips #1 screws underneath the DVD drive.
    Pergunte ao FixBot
    Comentar
  6. HP 15-R011DX RAM (Random Access Memory) Replacement: passo 6, imagem 1 %32 HP 15-R011DX RAM (Random Access Memory) Replacement: passo 6, imagem 2 %32 HP 15-R011DX RAM (Random Access Memory) Replacement: passo 6, imagem 3 %32
    • Flip the laptop and open.
    • Detach the keyboard by prying it free from the laptop using a spudger.
    • Do not completely remove the keyboard yet. It is still attached by a ribbon cable.
    • Disconnect the keyboard ribbon cable.
    Pergunte ao FixBot
    Comentar
  7. HP 15-R011DX RAM (Random Access Memory) Replacement: passo 7, imagem 1 %32 HP 15-R011DX RAM (Random Access Memory) Replacement: passo 7, imagem 2 %32
    • Disconnect the two narrow ribbon cables to the left of the keyboard connection.
    • Remove five 4 mm Phillips #1 screws from the metal tray for the keyboard.
    • Pry open the plastic casing using a spudger.
    • If struggling to remove the plastic case, check that all screws have been removed.
    Pergunte ao FixBot
    Comentar
  8. HP 15-R011DX RAM (Random Access Memory) Replacement, Hard Drive: passo 8, imagem 1 %32
    • Remove two 5 mm Phillips #1 screws located at the base of the hard drive.
    Pergunte ao FixBot
    Comentar
  9. HP 15-R011DX RAM (Random Access Memory) Replacement: passo 9, imagem 1 %32 HP 15-R011DX RAM (Random Access Memory) Replacement: passo 9, imagem 2 %32
    • Pull the hard drive upwards and away from the laptop.
    • The hard drive should disconnect from its port on the motherboard as shown in the second image.
    Pergunte ao FixBot
    Comentar
  10. HP 15-R011DX RAM (Random Access Memory) Replacement: passo 10, imagem 1 %32
    • Flip the hard drive over.
    • Remove the two 4 mm Phillips #1 screws from the base of the hard drive.
    • Remove the mounting brace (silver bracket) from the hard drive.
    Pergunte ao FixBot
    Comentar
  11. HP 15-R011DX RAM (Random Access Memory) Replacement, Motherboard: passo 11, imagem 1 %32 HP 15-R011DX RAM (Random Access Memory) Replacement, Motherboard: passo 11, imagem 2 %32
    • Remove the remaining two 5 mm Philips #1 screws from the motherboard.
    Pergunte ao FixBot
    Comentar
  12. HP 15-R011DX RAM (Random Access Memory) Replacement: passo 12, imagem 1 %32
    • Remove the tape from the display connector attached to the motherboard.
    • Disconnect the display connector from the motherboard.
    Pergunte ao FixBot
    Comentar
  13. HP 15-R011DX RAM (Random Access Memory) Replacement: passo 13, imagem 1 %32
    • Remove one 4 mm Phillips #1 screw from the wireless chip.
    • Remove the wireless chip from the motherboard.
    Pergunte ao FixBot
    Comentar
  14. HP 15-R011DX RAM (Random Access Memory) Replacement: passo 14, imagem 1 %32
    • Remove two 5 mm Phillips #1 screws from the USB component connected to the motherboard.
    • Lift the USB component until the band connecting it to the motherboard lifts off of the laptop.
    Pergunte ao FixBot
    Comentar
  15. HP 15-R011DX RAM (Random Access Memory) Replacement: passo 15, imagem 1 %32
    • Slowly lift the motherboard out of the computer.
    • Be sure that the I/O ports on the left side of the motherboard are not stuck on the laptop frame.
    • Disconnect the power connector from the motherboard as shown in the image.
    Pergunte ao FixBot
    Comentar
  16. HP 15-R011DX RAM (Random Access Memory) Replacement, RAM (Random Access Memory): passo 16, imagem 1 %32
    • Locate the RAM drive on the underside of the motherboard.
    Pergunte ao FixBot
    Comentar
  17. HP 15-R011DX RAM (Random Access Memory) Replacement: passo 17, imagem 1 %32 HP 15-R011DX RAM (Random Access Memory) Replacement: passo 17, imagem 2 %32
    • Push the locking tabs outward to release the RAM chip from the motherboard.
    Pergunte ao FixBot
    Comentar
  18. HP 15-R011DX RAM (Random Access Memory) Replacement: passo 18, imagem 1 %32
    • Remove the RAM chip by pulling the drive from the connectors.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 19
Ao todo: 1,401
