Ir para o conteúdo principal
HP 15-BA078DX RAM Replacement
O que você precisa
  1. HP 15-BA078DX RAM Replacement, Battery: passo 1, imagem 1 %32 HP 15-BA078DX RAM Replacement, Battery: passo 1, imagem 2 %32 HP 15-BA078DX RAM Replacement, Battery: passo 1, imagem 3 %32
    • Unclip the two latches on the bottom of the laptop.
    • Slide the battery straight out while holding the clip open.
    Pergunte ao FixBot
    Comentar
  2. HP 15-BA078DX RAM Replacement, Disc Drive: passo 2, imagem 1 %32
    • Using the Phillips #0 screwdriver, remove the 7.5mm screw from the underside of the plastic frame that holds the disc tray in place.
    Pergunte ao FixBot
    Comentar
  3. HP 15-BA078DX RAM Replacement: passo 3, imagem 1 %32 HP 15-BA078DX RAM Replacement: passo 3, imagem 2 %32 HP 15-BA078DX RAM Replacement: passo 3, imagem 3 %32
    • Remove the disk tray assembly by sliding it out from the side using the blue plastic opening tool.
    Pergunte ao FixBot
    Comentar
  4. HP 15-BA078DX RAM Replacement, Back Panel: passo 4, imagem 1 %32
    • Remove all of the remaining back panel screws with a #0 Phillips head screwdriver.
    • Remember to remove the two screws under the rubber feet.
    Pergunte ao FixBot
    Comentar
  5. HP 15-BA078DX RAM Replacement: passo 5, imagem 1 %32 HP 15-BA078DX RAM Replacement: passo 5, imagem 2 %32 HP 15-BA078DX RAM Replacement: passo 5, imagem 3 %32
    • Carefully use the blue plastic opening tool to pry the clam shell of the laptop apart.
    • You may need to flip the laptop over to unlatch all of the internal clips.
    Pergunte ao FixBot
    Comentar
  6. HP 15-BA078DX RAM Replacement: passo 6, imagem 1 %32 HP 15-BA078DX RAM Replacement: passo 6, imagem 2 %32 HP 15-BA078DX RAM Replacement: passo 6, imagem 3 %32
    • Carefully pull the shell of the computer apart.
    Pergunte ao FixBot
    Comentar
  7. HP 15-BA078DX RAM Replacement, RAM: passo 7, imagem 1 %32 HP 15-BA078DX RAM Replacement, RAM: passo 7, imagem 2 %32
    • Using a plastic spudger, unclip the latch locking the RAM to the motherboard.
    Pergunte ao FixBot
    Comentar
  8. HP 15-BA078DX RAM Replacement: passo 8, imagem 1 %32 HP 15-BA078DX RAM Replacement: passo 8, imagem 2 %32 HP 15-BA078DX RAM Replacement: passo 8, imagem 3 %32
    • Gently tilt the RAM sticks up and slide out each stick.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 21
Ao todo: 815
