Introdução
Is your keyboard being unresponsive? Are you not able to type on your laptop? If so, the keyboard may be faulty and it may be time to replace the keyboard in the device. Follow these instructions to remove and replace the keyboard in the HP 14-am052nr laptop.
O que você precisa
Turn the laptop over to its bottom so that the backside is facing you.
Using your fingers, push the two locking tabs inwards to release the battery.
Remove the battery from the device.
After removing the battery with the laptop on its back, expose screws that are hidden under the rubber feet and the center label.
Using the Phillips #0 screwdriver, remove fourteen (14) 6 mm screws from the back panel.
Using the Phillips #0 screwdriver, remove three 3 mm screws and five 3.5 mm screws from the motherboard.
