Ir para o conteúdo principal
HMDX Jam Plus Line In Jack Replacement
O que você precisa
  1. HMDX Jam Plus  Line In Jack Replacement, Battery: passo 1, imagem 1 %32 HMDX Jam Plus  Line In Jack Replacement, Battery: passo 1, imagem 2 %32 HMDX Jam Plus  Line In Jack Replacement, Battery: passo 1, imagem 3 %32
    • Flip the device over so the bottom is facing up.
    • Use the large plastic opening tool to gently pry the rubber base from the device.
    • Slowly move the plastic opening tool around the edge of the rubber base to separate it from the plastic.
    Pergunte ao FixBot
    Comentar
  2. HMDX Jam Plus  Line In Jack Replacement: passo 2, imagem 1 %32 HMDX Jam Plus  Line In Jack Replacement: passo 2, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the four black 9mm screws from the device.
    Pergunte ao FixBot
    Comentar
  3. HMDX Jam Plus  Line In Jack Replacement: passo 3, imagem 1 %32 HMDX Jam Plus  Line In Jack Replacement: passo 3, imagem 2 %32
    • Gently separate the base from the rest of the device to reveal the battery and the main board.
    Pergunte ao FixBot
    Comentar
  4. HMDX Jam Plus  Line In Jack Replacement: passo 4, imagem 1 %32 HMDX Jam Plus  Line In Jack Replacement: passo 4, imagem 2 %32 HMDX Jam Plus  Line In Jack Replacement: passo 4, imagem 3 %32
    • Carefully use the plastic opening tool to remove the glue around the battery and speaker connectors.
    • Pull gently on the connectors to separate each one from the main board.
    • The battery is connected to board in the red socket and the speaker is connected in the white socket.
    Pergunte ao FixBot
    Comentar
  5. HMDX Jam Plus  Line In Jack Replacement: passo 5, imagem 1 %32 HMDX Jam Plus  Line In Jack Replacement: passo 5, imagem 2 %32 HMDX Jam Plus  Line In Jack Replacement: passo 5, imagem 3 %32
    • Batteries can be very dangerous if punctured. Use extra caution when using tools around the battery.
    • Use the plastic opening tool to gently pry the battery free from the rest of the device.
    Pergunte ao FixBot
    Comentar
  6. HMDX Jam Plus  Line In Jack Replacement: passo 6, imagem 1 %32 HMDX Jam Plus  Line In Jack Replacement: passo 6, imagem 2 %32
    • Use new adhesive to secure battery back to the rest of the device.
    Pergunte ao FixBot
    Comentar
  7. HMDX Jam Plus  Line In Jack Replacement, Line In Jack: passo 7, imagem 1 %32 HMDX Jam Plus  Line In Jack Replacement, Line In Jack: passo 7, imagem 2 %32
    • Remove the three black 6mm screws from the main board using a Philips #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  8. HMDX Jam Plus  Line In Jack Replacement: passo 8, imagem 1 %32 HMDX Jam Plus  Line In Jack Replacement: passo 8, imagem 2 %32
    • Carefully lift the main board away from the plastic.
    • Lift the side with the buttons first and be careful not to damage the Line In Jack or the Micro USB Jack.
    Pergunte ao FixBot
    Comentar
  9. HMDX Jam Plus  Line In Jack Replacement: passo 9, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use the Micro soldering iron to heat up each pad and use the desoldering wick to wick up the melted solder.
    • The surface mount jack should pull from the surface without much force. Use tweezers to apply upward pressure on on the jack.
    • Do not apply too much heat to the board as it may damage other portions of the board.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Montana Tech, Team 10-3, Shirk Fall 2015 Membro de Montana Tech, Team 10-3, Shirk Fall 2015
MTUM-SHIRK-F15S10G3
4 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 15
Ao todo: 623
