Ir para o conteúdo principal
HMDX Jam Battery Replacement
O que você precisa
  1. HMDX Jam Battery Replacement, Opening speaker: passo 1, imagem 1 %32
    • Use the plastic opening tool to pry off the rubber cover at the bottom of the speaker.
    Pergunte ao FixBot
    Comentar
  2. HMDX Jam Battery Replacement, remove rubber cover: passo 2, imagem 1 %32
    • Gently remove the rubber cover to expose the screws. If necessary, poke holes through the glue residue to expose the screw heads.
    Pergunte ao FixBot
    Comentar
  3. HMDX Jam Battery Replacement, Remove screws: passo 3, imagem 1 %32
    • Once you have exposed the screws, use a #1 Phillips screwdriver to remove the four 9 mm screws.
    • It would be wise to use a magnetic mat for the screws for safekeeping.
    Pergunte ao FixBot
    Comentar
  4. HMDX Jam Battery Replacement, Exposing Battery: passo 4, imagem 1 %32
    • Once you've removed the screws, open the case slowly. The battery is covered in blue packaging.
    Pergunte ao FixBot
    Comentar
  5. HMDX Jam Battery Replacement, Removing Battery: passo 5, imagem 1 %32
    • Very gently remove the battery from the motherboard.
    Pergunte ao FixBot
    Comentar
  6. HMDX Jam Battery Replacement, Remove battery attachments: passo 6, imagem 1 %32 HMDX Jam Battery Replacement, Remove battery attachments: passo 6, imagem 2 %32
    • Use a solder gun to remove the battery attachments from the motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
42 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 1-1, Blackwell Winter 2015 Membro de USF Tampa, Team 1-1, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G1
4 Membros
Autoria de 2 guias
18Comentários do guia
Looks like a great solution to fixing the speaker with a battery with a short life span. But what's the amperage of the lithium barberry and where can I purchase one ?
Stephen Lavizzo - Responder Compartilhar
Did you ever find out where to purchase a new battery for it?
DJ Ethics - Responder Compartilhar
Hey Stephen. Can you tell me where i can buy a replacement battery for my P120
Lynchfield Daniel - Responder Compartilhar
On my Model: HX-P240A
KANYO 383541P 3.7V
520mAh 1.924Wh
534114364A17142
minhngoctruong - Responder Compartilhar
My Bluetooth speaker just has a rubber suction on the bottom. There is no area to replace a battery. Is there any way to reset I?
bdale46 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 21
Últimos 30 dias: 121
Ao todo: 98,667
