Ir para o conteúdo principal
Grip Tape Application
O que você precisa
    1. Grip Tape Application, Grip Tape Application: passo 1, imagem 1 %32
      • Peel off the paper backing from the sheet of grip tape.
      • Make sure you do not fold or wrinkle the grip tape.
      Pergunte ao FixBot
      Comentar
    2. Grip Tape Application: passo 2, imagem 1 %32
      • Center the sheet of grip tape evenly over the top of the skateboard deck.
      Pergunte ao FixBot
      Comentar
    3. Grip Tape Application: passo 3, imagem 1 %32 Grip Tape Application: passo 3, imagem 2 %32
      • Starting from the very middle and moving outward, firmly press down on the grip tape while smoothing out any air bubbles that start to form.
      Pergunte ao FixBot
      Comentar
    4. Grip Tape Application: passo 4, imagem 1 %32 Grip Tape Application: passo 4, imagem 2 %32
      • Use a screwdriver to scrape along the edges of the skateboard. This will remove some of the grip around the edges making the trimming process easier on you and your equipment.
      • You can use the utility knife to cut a perpendicular line in the excess grip tape if it is resisting the screwdriver too much.
      Pergunte ao FixBot
      Comentar
    5. Grip Tape Application: passo 5, imagem 1 %32 Grip Tape Application: passo 5, imagem 2 %32 Grip Tape Application: passo 5, imagem 3 %32
      • Use a utility knife to begin cutting around the edge of your skateboard to remove excess grip tape.
      • Angle your knife towards the inside of the skateboard to make it easier to cut a straight line.
      • Be careful when using the utility knife and always keep it pointed away from yourself and others.
      Pergunte ao FixBot
      Comentar
    6. Grip Tape Application: passo 6, imagem 1 %32
      • Once you have removed all of the excess grip tape, you can use the scraps to sand the edges of your cut to smooth out any small inconsistencies.
      • Use caution when sanding as the grip tape can become heated.
      Pergunte ao FixBot
      Comentar
    7. Grip Tape Application: passo 7, imagem 1 %32
      • If air bubbles persist, gently use a utility knife to poke a small hole in the grip tape at the center of the bubble and press out the air.
      Pergunte ao FixBot
      Comentar
    8. Grip Tape Application: passo 8, imagem 1 %32 Grip Tape Application: passo 8, imagem 2 %32
      • After you have finished applying your grip tape, you can use a small screwdriver to poke holes where your truck hardware will be installed.
      Pergunte ao FixBot
      Comentar
Conclusão
The next logical step in the assembly of a skateboard is to install skateboard trucks, please reference the Truck Installation guide.
4 outras pessoas executaram este guia.
Jared Stine
Membro desde: 10/05/12
800 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 6-32, Regan Fall 2012 Membro de Cal Poly, Team 6-32, Regan Fall 2012
CPSU-REGAN-F12S6G32
5 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 34
Ao todo: 8,553
