Ir para o conteúdo principal
Graco Paint Sprayers 17C325 2015 Gun Filter Replacement
O que você precisa
  1. Graco Paint Sprayers 17C325 2015 Gun Filter Replacement, Remove the Handle: passo 1, imagem 1 %32 Graco Paint Sprayers 17C325 2015 Gun Filter Replacement, Remove the Handle: passo 1, imagem 2 %32 Graco Paint Sprayers 17C325 2015 Gun Filter Replacement, Remove the Handle: passo 1, imagem 3 %32
    • Before you begin, make sure to follow the pressure relief procedure documented in the user manual before disconnecting and disassembling the spray gun.
    • Unscrew and remove the handle from the spray gun body.
    • You may need to use a pipe wrench to loosen the handle before removing it.
  2. Graco Paint Sprayers 17C325 2015 Gun Filter Replacement, Remove the Filter: passo 2, imagem 1 %32 Graco Paint Sprayers 17C325 2015 Gun Filter Replacement, Remove the Filter: passo 2, imagem 2 %32 Graco Paint Sprayers 17C325 2015 Gun Filter Replacement, Remove the Filter: passo 2, imagem 3 %32
    • Use your fingers to remove the blue-tipped filter from the inside of the handle.
Conclusão
4 outras pessoas executaram este guia.
Craig Lloyd
Membro desde: 02/10/16
35.519 Reputação
Autoria de 82 guias
3 comentários
It would be beneficial to have the part numbers in this information as well! Otherwise, great job! Thanks
JANET - Responder
part number for the gun filter??????
BRITTINEY - Responder
288749 60 mesh gun filter
RICHARD -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 41
Duração total: 1,880
