Ir para o conteúdo principal
Google Stadia Controller Buttons Replacement
O que você precisa
  1. Google Stadia Controller Buttons Replacement, Loosen the screw cover adhesive: passo 1, imagem 1 %32
    • Apply a heated iOpener to the rear side of the Stadia controller where the screw cover is located to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
  2. Google Stadia Controller Buttons Replacement, Insert an opening pick: passo 2, imagem 1 %32 Google Stadia Controller Buttons Replacement, Insert an opening pick: passo 2, imagem 2 %32
    • Insert the tip of an opening pick into the gap between the plastic screw cover and the rear case of the controller.
  3. Google Stadia Controller Buttons Replacement, Remove the screw cover: passo 3, imagem 1 %32 Google Stadia Controller Buttons Replacement, Remove the screw cover: passo 3, imagem 2 %32 Google Stadia Controller Buttons Replacement, Remove the screw cover: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Slide the opening pick along the screw cover to slice the adhesive.
    • Use a pair of tweezers or your fingers to remove the screw cover.
    • You might want to replace the screw cover adhesive during reassembly. Apply a bit of high-concentration isopropyl alcohol (>90%) to a Q-tip or use a cleaning pad to gently remove the leftover adhesive on the rear cover of the controller before installing new adhesive.
  4. Google Stadia Controller Buttons Replacement, Unfasten the rear case screw: passo 4, imagem 1 %32
    • Use a Torx T8 screwdriver to remove the 9.6 mm-long screw securing the rear case.
  5. Google Stadia Controller Buttons Replacement, Disassembly information: passo 5, imagem 1 %32 Google Stadia Controller Buttons Replacement, Disassembly information: passo 5, imagem 2 %32
    • The front cover assembly of the Stadia controller is held in place by various tight plastic clamps. They are very hard to open and snap back in place easily.
    • The opening procedure requires some force, however, try to avoid damaging your controller case along the way.
  6. Google Stadia Controller Buttons Replacement, Pry open the stadia controller: passo 6, imagem 1 %32 Google Stadia Controller Buttons Replacement, Pry open the stadia controller: passo 6, imagem 2 %32 Google Stadia Controller Buttons Replacement, Pry open the stadia controller: passo 6, imagem 3 %32
    • Insert a Jimmy into the gap between the front and back cover assembly at the inside of the left controller handle.
    • To make sure you insert the Jimmy at the correct position where the clamps are located, you can use this photo.
    • Tilt the Jimmy upwards and push it into the gap between the covers at the same time to pry open the plastic clamp. You should hear a clack noise once the clamp pops open.
    • Once the clamp is completely open, the gap between the two controller covers should be about 2-3 mm wide.
  7. Google Stadia Controller Buttons Replacement, Insert an opening pick: passo 7, imagem 1 %32 Google Stadia Controller Buttons Replacement, Insert an opening pick: passo 7, imagem 2 %32
    • Insert an opening pick in a steep angle into the gap you created to prevent the first clamp from popping back into its closed position.
  8. Google Stadia Controller Buttons Replacement, Pry open the Stadia controller: passo 8, imagem 1 %32 Google Stadia Controller Buttons Replacement, Pry open the Stadia controller: passo 8, imagem 2 %32 Google Stadia Controller Buttons Replacement, Pry open the Stadia controller: passo 8, imagem 3 %32
    • Insert a Jimmy into the gap between the front and back cover assembly at the outside of the left bottom end of the controller handle.
    • Repeat the previous opening procedure to open the three plastic clamps at the outside of the left controller handle.
  9. Google Stadia Controller Buttons Replacement: passo 9, imagem 1 %32 Google Stadia Controller Buttons Replacement: passo 9, imagem 2 %32 Google Stadia Controller Buttons Replacement: passo 9, imagem 3 %32
    • Insert a Jimmy into the gap between the front and back cover assembly between the left shoulder button and the charging port at the top edge of the Stadia controller.
    • Repeat the previous procedure at the clamp between the right shoulder button and the charging port.
  10. Google Stadia Controller Buttons Replacement: passo 10, imagem 1 %32 Google Stadia Controller Buttons Replacement: passo 10, imagem 2 %32 Google Stadia Controller Buttons Replacement: passo 10, imagem 3 %32
    • Insert a Jimmy into the gap between the front and back cover assembly at the right edge of the right controller handle.
    • Repeat the previous opening procedure to open the three plastic clamps at the outside of the right controller handle.
  11. Google Stadia Controller Buttons Replacement: passo 11, imagem 1 %32 Google Stadia Controller Buttons Replacement: passo 11, imagem 2 %32
    • Insert a Jimmy into the gap between the front and back cover assembly at the inside of the right controller handle.
    • Repeat the previous opening procedure to open plastic clamps at the inside of the left controller handle.
  12. Google Stadia Controller Buttons Replacement: passo 12, imagem 1 %32 Google Stadia Controller Buttons Replacement: passo 12, imagem 2 %32 Google Stadia Controller Buttons Replacement: passo 12, imagem 3 %32
    • Insert a Jimmy into the gap between the front and back cover assembly at the bottom edge of the Stadia controller right to the headphone jack.
    • Repeat the previous procedure at the clamp left to the headphone jack.
    • Do not try to remove the front cover assembly all the way yet. It's still connected to the rear cover assembly.
  13. Google Stadia Controller Buttons Replacement, Unfold the front cover assembly: passo 13, imagem 1 %32 Google Stadia Controller Buttons Replacement, Unfold the front cover assembly: passo 13, imagem 2 %32 Google Stadia Controller Buttons Replacement, Unfold the front cover assembly: passo 13, imagem 3 %32
    • Avoid straining the front cover assembly cable during this step.
    • Carefully lift the front cover assembly and fold it to the left side of the Google Stadia controller.
  14. Google Stadia Controller Buttons Replacement, Remove the adhesive tape: passo 14, imagem 1 %32 Google Stadia Controller Buttons Replacement, Remove the adhesive tape: passo 14, imagem 2 %32
    • Use a pair of tweezers to peel the clear protective tape off the ZIF connector on the left side of the rear case.
  15. Google Stadia Controller Buttons Replacement, Open the ZIF connector: passo 15, imagem 1 %32 Google Stadia Controller Buttons Replacement, Open the ZIF connector: passo 15, imagem 2 %32
    • Use the pointed end of a spudger to open the ZIF connector holding the button contact board cable in place.
  16. Google Stadia Controller Buttons Replacement, Disconnect the flex cable: passo 16, imagem 1 %32 Google Stadia Controller Buttons Replacement, Disconnect the flex cable: passo 16, imagem 2 %32 Google Stadia Controller Buttons Replacement, Disconnect the flex cable: passo 16, imagem 3 %32
    • Use a pair of tweezers to carefully disconnect the flex cable of the button unit by pulling it out of the ZIF connector in a flat angle.
    • Separate the front from the rear assembly.
    • Remove the thumbsticks by pulling them straight upwards for an easier handling in case you want to do further disassembly.
  17. Google Stadia Controller Buttons Replacement, Unfasten the screws: passo 17, imagem 1 %32
    • Use a Torx T6 screwdriver to remove the three 6.2 mm-long screws securing the front button contact board.
  18. Google Stadia Controller Buttons Replacement, Remove the front button contact board: passo 18, imagem 1 %32 Google Stadia Controller Buttons Replacement, Remove the front button contact board: passo 18, imagem 2 %32
  19. Google Stadia Controller Buttons Replacement, Remove the rubber gasket: passo 19, imagem 1 %32 Google Stadia Controller Buttons Replacement, Remove the rubber gasket: passo 19, imagem 2 %32
    • Use a pair of tweezers or your fingers to remove the rubber gasket on the A, B, X and Y buttons.
  20. Google Stadia Controller Buttons Replacement, Remove the buttons: passo 20, imagem 1 %32 Google Stadia Controller Buttons Replacement, Remove the buttons: passo 20, imagem 2 %32 Google Stadia Controller Buttons Replacement, Remove the buttons: passo 20, imagem 3 %32
    • Use a pair of tweezers to remove the A, B, X and Y buttons.
    • Since the buttons are equipped with little plastic nibs for orientation, there isn't a risk of inserting them in the wrong position during reassembly.
  21. Google Stadia Controller Buttons Replacement, Remove the rubber gasket: passo 21, imagem 1 %32 Google Stadia Controller Buttons Replacement, Remove the rubber gasket: passo 21, imagem 2 %32
    • Use a pair of tweezers or your fingers to remove the rubber gasket on the menu and the capture button.
  22. Google Stadia Controller Buttons Replacement, Remove the buttons: passo 22, imagem 1 %32 Google Stadia Controller Buttons Replacement, Remove the buttons: passo 22, imagem 2 %32 Google Stadia Controller Buttons Replacement, Remove the buttons: passo 22, imagem 3 %32
    • Use a pair of tweezers to remove the menu and capture button.
  23. Google Stadia Controller Buttons Replacement, Remove the rubber gasket: passo 23, imagem 1 %32 Google Stadia Controller Buttons Replacement, Remove the rubber gasket: passo 23, imagem 2 %32
    • Use a pair of tweezers or your fingers to remove the rubber gasket on the Stadia button.
  24. Google Stadia Controller Buttons Replacement, Remove the button: passo 24, imagem 1 %32 Google Stadia Controller Buttons Replacement, Remove the button: passo 24, imagem 2 %32
    • Use a pair of tweezers to remove the Stadia button.
  25. Google Stadia Controller Buttons Replacement, Remove the rubber gasket: passo 25, imagem 1 %32 Google Stadia Controller Buttons Replacement, Remove the rubber gasket: passo 25, imagem 2 %32
    • Use a pair of tweezers or your fingers to remove the rubber gasket on the Google assistant and option button.
  26. Google Stadia Controller Buttons Replacement, Remove the buttons: passo 26, imagem 1 %32 Google Stadia Controller Buttons Replacement, Remove the buttons: passo 26, imagem 2 %32 Google Stadia Controller Buttons Replacement, Remove the buttons: passo 26, imagem 3 %32
    • Use a pair of tweezers to remove the Google assistant and option button.
  27. Google Stadia Controller Buttons Replacement, Remove the direction pad: passo 27, imagem 1 %32 Google Stadia Controller Buttons Replacement, Remove the direction pad: passo 27, imagem 2 %32 Google Stadia Controller Buttons Replacement, Remove the direction pad: passo 27, imagem 3 %32
    • Use a pair of tweezers or your fingers to remove the direction pad.
Conclusão
Uma outra pessoa concluiu este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
256.614 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 25.502 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 27
Últimos 30 dias: 84
Ao todo: 2,745
