Ir para o conteúdo principal
Google Pixelbook Go Battery Replacement
O que você precisa
  1. Google Pixelbook Go Battery Replacement, Back Panel: passo 1, imagem 1 %32 Google Pixelbook Go Battery Replacement, Back Panel: passo 1, imagem 2 %32
    • Flip the device so that the back is facing up.
    • Peel the rubber stoppers off the top and bottom of the device.
  2. Google Pixelbook Go Battery Replacement: passo 2, imagem 1 %32 Google Pixelbook Go Battery Replacement: passo 2, imagem 2 %32
    • Remove ten 3 mm screws from around the edge of the back panel using a T5 Torx screwdriver.
  3. Google Pixelbook Go Battery Replacement: passo 3, imagem 1 %32 Google Pixelbook Go Battery Replacement: passo 3, imagem 2 %32 Google Pixelbook Go Battery Replacement: passo 3, imagem 3 %32
    • Use an iFixit opening tool to pry up the back panel cover.
    • There is an orange ribbon cable that connects the cover to the base, so don't separate the two pieces completely.
    • Remove the single 2 mm screw using a Torx T3 screwdriver.
    • Disconnect the orange cable from the base of the device.
  4. Google Pixelbook Go Battery Replacement: passo 4, imagem 1 %32
    • Insert wisdom here.
  5. Google Pixelbook Go Battery Replacement, Battery: passo 5, imagem 1 %32
    • If your replacement battery comes with a new cover already attached, disregard this step.
    • Use an iFixit opening tool to peel back the adhesive on the entire battery system.
    • Carefully remove battery from the base.
    • Align the new battery system with the cover and attach using adhesive or double-sided tape.
Conclusão
Caroline Gilliard
Membro desde: 03/01/23
81 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 30
Últimos 30 dias: 135
Duração total: 2,261
