Ir para o conteúdo principal
Google Pixelbook Battery (Back Panel) Replacement
O que você precisa
    1. Google Pixelbook Battery (Back Panel) Replacement, Battery (Back Panel): passo 1, imagem 1 %32 Google Pixelbook Battery (Back Panel) Replacement, Battery (Back Panel): passo 1, imagem 2 %32 Google Pixelbook Battery (Back Panel) Replacement, Battery (Back Panel): passo 1, imagem 3 %32
      • Use the iFixit opening tools or a metal spudger to pry the rubber covers off the back of your Pixelbook.
      • Peel the linings off completely until the back of the Pixelbook looks bare.
      Pergunte ao FixBot
      Comentar
    2. Google Pixelbook Battery (Back Panel) Replacement: passo 2, imagem 1 %32 Google Pixelbook Battery (Back Panel) Replacement: passo 2, imagem 2 %32
      • Remove the two yellow 2.0mm screws by using a T3 Torx screwdriver.
      Pergunte ao FixBot
      Comentar
    3. Google Pixelbook Battery (Back Panel) Replacement: passo 3, imagem 1 %32 Google Pixelbook Battery (Back Panel) Replacement: passo 3, imagem 2 %32 Google Pixelbook Battery (Back Panel) Replacement: passo 3, imagem 3 %32
      • Remove the seventeen 3.0mm T5 Torx screws from the bottom panel.
      Pergunte ao FixBot
      Comentar
    4. Google Pixelbook Battery (Back Panel) Replacement: passo 4, imagem 1 %32 Google Pixelbook Battery (Back Panel) Replacement: passo 4, imagem 2 %32 Google Pixelbook Battery (Back Panel) Replacement: passo 4, imagem 3 %32
      • Use the nylon spudger to pry the edge of the Pixelbook up until you can grab the edge with your fingers.
      • Open the back panel completely and lay it flat so you see the whole inside of the computer.
      Pergunte ao FixBot
      Comentar
    5. Google Pixelbook Battery (Back Panel) Replacement: passo 5, imagem 1 %32 Google Pixelbook Battery (Back Panel) Replacement: passo 5, imagem 2 %32
      • Remove the yellow 2.0mm screw from the middle of the panel by using the T3 Torx screwdriver to turn the screw counterclockwise.
      Pergunte ao FixBot
      Comentar
    6. Google Pixelbook Battery (Back Panel) Replacement: passo 6, imagem 1 %32 Google Pixelbook Battery (Back Panel) Replacement: passo 6, imagem 2 %32
      • Remove the small, black casing by using the spudger to lift it up from its place.
      Pergunte ao FixBot
      Comentar
    7. Google Pixelbook Battery (Back Panel) Replacement: passo 7, imagem 1 %32
      • Disconnect the flat, black cord from the main component by using a spudger to push it out of the slot, or by using your hand to carefully pull it out.
      • Your back panel is now free from the main component.
      Pergunte ao FixBot
      Comentar
Conclusão
33 outras pessoas executaram este guia.
Equipe
Cal Poly, Team S18-G1, Livingston Winter 2018 Membro de Cal Poly, Team S18-G1, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G1
4 Membros
Autoria de 43 guias
25Comentários do guia
Question; with the rubber pads removed from the bottom…is there adhesive and if so, what’s best used to replace those and make it look factory stock again?
Fabian Aldo Santiago - Responder Compartilhar
The rubber pads are fixed with double sided tape.
Kornel Schwarcz - Responder Compartilhar
I just use Isopropyl alcohol to quickly and completely remove any adhesive residue and use an ample amount of JB Weld and Automotive Bondo to get the unit ready. Use a wet rag to remove any excess adhesive. Do not fo0rget to centrealize the Feline Eyelash right at the longest point of the night and invokie MARDUK!!! AAAHHRHRGH.
MyLil Hottie - Responder Compartilhar
So yeah basic Chemistry coupled with the ‘Dark Arts’ have created a sustainable situation.!
Where did you buy the back case replacement part?
cartercapelli - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 73
Últimos 30 dias: 336
Ao todo: 43,314
