Ir para o conteúdo principal
Google Pixel C Screen Replacement
O que você precisa
    1. Google Pixel C Screen Replacement, Screen: passo 1, imagem 1 %32
      • Ensure that the device is completely powered down before beginning to take it apart
      • Use a heat gun to melt the adhesive that holds the screen to the device
      • Move the heat gun around the edge of the screen for approximately 1 minute, or until the screen can be lifted off in the next step.
      • Make sure not to heat the screen for too long because too much can damage other components inside the tablet.
      Pergunte ao FixBot
      Comentar
    2. Google Pixel C Screen Replacement: passo 2, imagem 1 %32 Google Pixel C Screen Replacement: passo 2, imagem 2 %32
      • Use a suction cup to assist in lifting the screen while prying around its edges with a plastic spudger.
      • If necessary use a metal spudger to pry the screen up, taking care not to scratch the device.
      • Be careful not to pull the screen too far off. It will still be attached to the device by a cable for the front facing camera and the wide display data cable.
      • Reattaching the screen will require adhesive to ensure that it stays in place.
      Pergunte ao FixBot
      Comentar
    3. Google Pixel C Screen Replacement: passo 3, imagem 1 %32 Google Pixel C Screen Replacement: passo 3, imagem 2 %32
      • Detach the cables for the camera by lifting the small flap using the tip of your fingernail or a spudger. Gently pull the ribbon cable out.
      Pergunte ao FixBot
      Comentar
    4. Google Pixel C Screen Replacement: passo 4, imagem 1 %32 Google Pixel C Screen Replacement: passo 4, imagem 2 %32
      Ferramenta utilizada neste passo:
      • Follow the same removal procedure to detach the wide gold cable.
      • When reattaching cables, it is helpful to use tweezers to slide the cable in before securing it down with the flap.
      • This device is missing a battery, so the device that you are working on may appear slightly different inside.
      Pergunte ao FixBot
      Comentar
Conclusão
9 outras pessoas executaram este guia.
Equipe
Cal Poly, Team S21-G4, Livingston Spring 2017 Membro de Cal Poly, Team S21-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G4
4 Membros
Autoria de 11 guias
28Comentários do guia
Where can a replacement screen be located?
Ronnie Williams - Responder Compartilhar
Where can i buy a spare screen for this tablet?
Luigi Abbinante - Responder Compartilhar
Yes, I have to buy the screen too, but where??
Кирилл Кнышев - Responder Compartilhar
All very nice but unfortunately useless without knowing where to get the parts :(
Lorenzo Braschi - Responder Compartilhar
Ciao Lorenzo, sei poi riuscito a trovare il ricambio?
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 17
Últimos 30 dias: 81
Ao todo: 19,615
