Introdução
This guide will outline how to replace the power button should it be non responsive or faulty.
O que você precisa
Use a heat gun to melt the adhesive that holds the screen to the device
Move the heat gun around the edge of the screen for approximately 1 minute, or until the screen can be lifted off in the next step.
To reassemble your device, follow these instructions in reverse order. New adhesive will be needed to re-apply the screen.
Uma outra pessoa concluiu este guia.
1Comentário do guia
I have replaced the power/volume button flex with these instructions with a reportably working item, but power button still doesn't work. The volume buttons work just fine. Any other ideas about what might be the problem?
