Ir para o conteúdo principal
Google Pixel 2 Display Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. Google Pixel 2 Display Replacement, Display: passo 1, imagem 1 %32 Google Pixel 2 Display Replacement, Display: passo 1, imagem 2 %32
    • Heat up the iOpener in the microwave for 30 seconds.
    • Place the iOpener clear-side down on each edge of the phone for approximately 30 seconds.
    • Place the iOpener on top of the screen for an additional 30 seconds.
    • Be careful with the iOpener as it will get extremely hot.
    Pergunte ao FixBot
    Comentar
  2. Google Pixel 2 Display Replacement: passo 2, imagem 1 %32 Google Pixel 2 Display Replacement: passo 2, imagem 2 %32 Google Pixel 2 Display Replacement: passo 2, imagem 3 %32
    • Attach the suction cup to the display by placing it on top of the display and pushing down on the top of the cup until it is flat.
    • Separate the display and the device by inserting the plastic opening tool between them and sliding the plastic opening tool along the perimeter of the display.
    • It is normal to hear popping noises as the plastic opening tool breaks the connection between the display and the device.
    • Remove the display from the device by grabbing the ring of the suction cup and pulling up.
    Pergunte ao FixBot
    Comentar
  3. Google Pixel 2 Display Replacement: passo 3, imagem 1 %32 Google Pixel 2 Display Replacement: passo 3, imagem 2 %32 Google Pixel 2 Display Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Remove the T4 4.0-mm screws from the latch under the display by turning the screwdriver counterclockwise.
    • Pull the latch off of the device by grabbing it with the tweezers and pulling up.
    Pergunte ao FixBot
    Comentar
  4. Google Pixel 2 Display Replacement: passo 4, imagem 1 %32
    • Remove the connector underneath the latch by grabbing it with the tweezers and lifting up.
    • It is normal to hear a popping noise during this step.
    • When reassembling, simply use your finger to pop this piece back into place by pushing it down into the device.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Monica Andres
Membro desde: 01/24/18
289 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S18-G5, Livingston Winter 2018 Membro de Cal Poly, Team S18-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G5
4 Membros
Autoria de 18 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 33
Ao todo: 1,350
