Ir para o conteúdo principal
Google Home Sound Driver Replacement
O que você precisa
  1. Google Home Sound Driver Replacement, Interconnect Cable: passo 1, imagem 1 %32 Google Home Sound Driver Replacement, Interconnect Cable: passo 1, imagem 2 %32 Google Home Sound Driver Replacement, Interconnect Cable: passo 1, imagem 3 %32
    • Removing the lid too quickly could cause you to tear the interconnect cable that attaches the base to the top of the lid.
    • Pull off the Google Home’s magnetically attached base and set it aside.
    • Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
    • After all four screws are out, pop the lid off the device to open the capsule.
    Pergunte ao FixBot
    Comentar
  2. Google Home Sound Driver Replacement: passo 2, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Carefully remove the interconnect cable using a pair of tweezers.
    Pergunte ao FixBot
    Comentar
  3. Google Home Sound Driver Replacement, Mute Button Switch: passo 3, imagem 1 %32 Google Home Sound Driver Replacement, Mute Button Switch: passo 3, imagem 2 %32
    • Remove the ‘O-ring’ that wraps around the device holding the switch panel in place.
    Pergunte ao FixBot
    Comentar
  4. Google Home Sound Driver Replacement: passo 4, imagem 1 %32 Google Home Sound Driver Replacement: passo 4, imagem 2 %32
    • Using a Torx T6 screwdriver head, unscrew the four black 1.7mm Torx screws.
    • Remove the panel and the mute button switch. If done correctly you should now be able to see the device’s guitar-shaped motherboard.
    Pergunte ao FixBot
    Comentar
  5. Google Home Sound Driver Replacement, Motherboard: passo 5, imagem 1 %32 Google Home Sound Driver Replacement, Motherboard: passo 5, imagem 2 %32
    • Disconnect the foam-padded, red and black cable that connects the motherboard to the sound driver, by squeezing and pulling on the tab
    • Disconnect the orange interconnect cable that connects the bottom of the device to the motherboard by pulling straight out on the orange tab.
    Pergunte ao FixBot
    Comentar
  6. Google Home Sound Driver Replacement: passo 6, imagem 1 %32 Google Home Sound Driver Replacement: passo 6, imagem 2 %32
    • Using a Torx T6 screwdriver head, unscrew the five silver 1.7mm Torx screws keeping the motherboard in place.
    • Remove the motherboard.
    Pergunte ao FixBot
    Comentar
  7. Google Home Sound Driver Replacement, Sound Driver: passo 7, imagem 1 %32 Google Home Sound Driver Replacement, Sound Driver: passo 7, imagem 2 %32
    • Using a Torx T6 screwdriver head, unscrew the four black 1.7mm Torx screws on the bottom of the device.
    • For this step you will need a T6 screwdriver with an extra long head to reach the screws.
    Pergunte ao FixBot
    Comentar
  8. Google Home Sound Driver Replacement: passo 8, imagem 1 %32 Google Home Sound Driver Replacement: passo 8, imagem 2 %32
    • Using a Torx T6 screwdriver head, unscrew the six black 1.7mm Torx screws on the side of the device.
    Pergunte ao FixBot
    Comentar
  9. Google Home Sound Driver Replacement: passo 9, imagem 1 %32 Google Home Sound Driver Replacement: passo 9, imagem 2 %32
    • Pull apart the black casing to reveal the sound driver.
    • Remove the sound driver.
    Pergunte ao FixBot
    Comentar
Conclusão
6 outras pessoas executaram este guia.
Gabe Hyun
Membro desde: 04/17/18
844 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S24-G11, Maness Spring 2018 Membro de Cal Poly, Team S24-G11, Maness Spring 2018
CPSU-MANESS-S18S24G11
4 Membros
Autoria de 5 guias
4Comentários do guia
I have a torn speaker cone. Can these be replaced and where can I buy the parts
rchrdsmmnds - Responder Compartilhar
I would like to know where I can buy a replacement speaker for my Google Home. Thanks in advance P.s has anybody else had their speaker blow on them on the Google Home?
Mark Goff - Responder Compartilhar
Looking for replacement speaker, where do I find?
Corey Anderson - Responder Compartilhar
replacement speaker for google home, someone knows here i find?
model:PLS -50N25AL07-04
or compatible speaker
vinyboylima - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 21
Últimos 30 dias: 71
Ao todo: 2,998
