Ir para o conteúdo principal
Google Home Mute Button Switch Replacement
O que você precisa
  1. Google Home Mute Button Switch Replacement, Interconnect Cable: passo 1, imagem 1 %32 Google Home Mute Button Switch Replacement, Interconnect Cable: passo 1, imagem 2 %32 Google Home Mute Button Switch Replacement, Interconnect Cable: passo 1, imagem 3 %32
    • Removing the lid too quickly could cause you to tear the interconnect cable that attaches the base to the top of the lid.
    • Pull off the Google Home’s magnetically attached base and set it aside.
    • Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
    • After all four screws are out, pop the lid off the device to open the capsule.
    Pergunte ao FixBot
    Comentar
  2. Google Home Mute Button Switch Replacement: passo 2, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Carefully remove the interconnect cable using a pair of tweezers.
    Pergunte ao FixBot
    Comentar
  3. Google Home Mute Button Switch Replacement, Mute Button Switch: passo 3, imagem 1 %32 Google Home Mute Button Switch Replacement, Mute Button Switch: passo 3, imagem 2 %32
    • Remove the ‘O-ring’ that wraps around the device holding the switch panel in place.
    Pergunte ao FixBot
    Comentar
  4. Google Home Mute Button Switch Replacement: passo 4, imagem 1 %32 Google Home Mute Button Switch Replacement: passo 4, imagem 2 %32
    • Using a Torx T6 screwdriver head, unscrew the four black 1.7mm Torx screws.
    • Remove the panel and the mute button switch. If done correctly you should now be able to see the device’s guitar-shaped motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Gabe Hyun
Membro desde: 04/17/18
844 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S24-G11, Maness Spring 2018 Membro de Cal Poly, Team S24-G11, Maness Spring 2018
CPSU-MANESS-S18S24G11
4 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 50
Ao todo: 1,306
