Ir para o conteúdo principal
Google Cr-48 Chromebook Bottom Casing Replacement
O que você precisa
  1. Google Cr-48 Chromebook Bottom Casing Replacement, Battery: passo 1, imagem 1 %32 Google Cr-48 Chromebook Bottom Casing Replacement, Battery: passo 1, imagem 2 %32 Google Cr-48 Chromebook Bottom Casing Replacement, Battery: passo 1, imagem 3 %32
    • To take out the battery, slide the switch on the bottom of the laptop.
    • The battery should then pop out and you can remove it.
    Pergunte ao FixBot
    Comentar
  2. Google Cr-48 Chromebook Bottom Casing Replacement, Bottom Casing: passo 2, imagem 1 %32 Google Cr-48 Chromebook Bottom Casing Replacement, Bottom Casing: passo 2, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using a pair of tweezers, remove the two rear rubber feet. You should then see the two screws underneath.
    Pergunte ao FixBot
    Comentar
  3. Google Cr-48 Chromebook Bottom Casing Replacement: passo 3, imagem 1 %32 Google Cr-48 Chromebook Bottom Casing Replacement: passo 3, imagem 2 %32 Google Cr-48 Chromebook Bottom Casing Replacement: passo 3, imagem 3 %32
    • First, position the computer to have the silver battery compartment closest to you. Then, using a Phillips #00 screwdriver, remove the ten 3 mm screws in the battery compartment.
    • Now, using the same screwdriver, remove the two 4.5 mm screws that were underneath the previously removed rubber feet.
    Pergunte ao FixBot
    Comentar
  4. Google Cr-48 Chromebook Bottom Casing Replacement: passo 4, imagem 1 %32 Google Cr-48 Chromebook Bottom Casing Replacement: passo 4, imagem 2 %32 Google Cr-48 Chromebook Bottom Casing Replacement: passo 4, imagem 3 %32
    • Starting where the body of the laptop and the laptop screen meet, pry apart the lower case from the rest of the laptop.
    • The case is easier to remove when separating in a clockwise motion, as seen in the pictures.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
CSU Fullerton, Team 2-2, Bruce Fall 2014 Membro de CSU Fullerton, Team 2-2, Bruce Fall 2014
CSUF-BRUCE-F14S2G2
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 30
Ao todo: 1,182
