Ir para o conteúdo principal
Goal Zero Rock Out 2 #94007 Speaker Repair
O que você precisa
  1. Goal Zero Rock Out 2 #94007 Speaker Repair, Goal Zero Rock Out 2 #94007 Speaker Repair: passo 1, imagem 1 %32 Goal Zero Rock Out 2 #94007 Speaker Repair, Goal Zero Rock Out 2 #94007 Speaker Repair: passo 1, imagem 2 %32 Goal Zero Rock Out 2 #94007 Speaker Repair, Goal Zero Rock Out 2 #94007 Speaker Repair: passo 1, imagem 3 %32
    • Power off your speaker before beginning disassembly.
    • Use a 2 mm Allen Key to remove eight 13 mm screws from the faceplate.
    • Use a spudger to remove the faceplate and set it aside.
  2. Goal Zero Rock Out 2 #94007 Speaker Repair: passo 2, imagem 1 %32 Goal Zero Rock Out 2 #94007 Speaker Repair: passo 2, imagem 2 %32 Goal Zero Rock Out 2 #94007 Speaker Repair: passo 2, imagem 3 %32
    • Remove the gray center piece and yellow rubber lining.
  3. Goal Zero Rock Out 2 #94007 Speaker Repair: passo 3, imagem 1 %32 Goal Zero Rock Out 2 #94007 Speaker Repair: passo 3, imagem 2 %32 Goal Zero Rock Out 2 #94007 Speaker Repair: passo 3, imagem 3 %32
    • Use a Phillips #0 screwdriver to remove four 12 mm screws from the speaker body.
    • Unzip the speaker case.
    • Turn the the speaker over so the bottom is facing up.
  4. Goal Zero Rock Out 2 #94007 Speaker Repair: passo 4, imagem 1 %32 Goal Zero Rock Out 2 #94007 Speaker Repair: passo 4, imagem 2 %32 Goal Zero Rock Out 2 #94007 Speaker Repair: passo 4, imagem 3 %32
    • Remove speaker from cloth case.
  5. Goal Zero Rock Out 2 #94007 Speaker Repair: passo 5, imagem 1 %32 Goal Zero Rock Out 2 #94007 Speaker Repair: passo 5, imagem 2 %32
    • Hold the speaker and gently separate the two parts.
    • Don't yank or pull it apart as the two halves are connected by cables.
  6. Goal Zero Rock Out 2 #94007 Speaker Repair: passo 6, imagem 1 %32 Goal Zero Rock Out 2 #94007 Speaker Repair: passo 6, imagem 2 %32 Goal Zero Rock Out 2 #94007 Speaker Repair: passo 6, imagem 3 %32
    • Use a Phillips #0 screwdriver to remove the four 12 mm screws securing the center resonator.
    • Carefully remove center resonator from the enclosure.
  7. Goal Zero Rock Out 2 #94007 Speaker Repair: passo 7, imagem 1 %32 Goal Zero Rock Out 2 #94007 Speaker Repair: passo 7, imagem 2 %32 Goal Zero Rock Out 2 #94007 Speaker Repair: passo 7, imagem 3 %32
    • This step requires soldering. Soldering can cause injuries such as burns to the skin. It can also produce fumes that are harmful so working in a well-ventilated area is advised.
    • Use wire strippers to remove about 6 mm of insulation from the detached speaker wire.
    • Set the soldering iron to 350 degrees.
    • Add solder to the tip of the iron and then touch the tip to exposed wire.
    • Join the wire with the electrical contact on the speaker.
Conclusão
Ricardo Arevalo Castaneda
Membro desde: 03/05/24
157 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 11
Últimos 30 dias: 25
Duração total: 50
