Ir para o conteúdo principal
GoPro Hero4 Silver Front Panel Replacement
O que você precisa
    1. GoPro Hero4 Silver Front Panel Replacement, Front Panel: passo 1, imagem 1 %32 GoPro Hero4 Silver Front Panel Replacement, Front Panel: passo 1, imagem 2 %32 GoPro Hero4 Silver Front Panel Replacement, Front Panel: passo 1, imagem 3 %32
      • Start by removing the silver plastic face from the camera using a plastic opening tool. Insert the plastic opening tool into the middle of each edge and lift up the tabs that keep the camera face on.
      • The seven plastic tab locations are marked in red.
      • Try using the plastic opening tool before switching to the metal spudger. We tried using the plastic opening tool to pry the camera face off, but found that it did not give us enough leverage.
      • There may be glue holding the camera face on to the housing. Be careful not to flex the camera face too much, or it will crack.
      Pergunte ao FixBot
      Comentar
Conclusão
15 outras pessoas executaram este guia.
Zack Hoover
Membro desde: 08/27/15
1.109 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 2-1, Blackwell Fall 2015 Membro de USF Tampa, Team 2-1, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G1
4 Membros
Autoria de 20 guias
2Comentários do guia
Am I mistaken, or are there missing steps in this guide?
Tom Fox - Responder Compartilhar
Looks like a simple remove/replace guide. Only one step needed.
justincarver - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 58
Ao todo: 12,764
