Introdução
If the pictures or video are fuzzy or unable to focus, the lens may need replacement. Follow this guide to do so.
O que você precisa
Ferramenta utilizada neste passo:Tweezers$4.99
Remove the faceplate by carefully prying around the edge using a plastic opening tool. Loosen the clips on the edge, then pull the faceplate off.
Use the tweezers to lift the faceplate from the rest of the device.
Using a plastic opening tool, separate the camera sensor's connector from the motherboard.
Using a #00 Phillips head screwdriver, remove the following screws:
Three 2 mm screw
5 outras pessoas executaram este guia.
1Comentário do guia
Between step 6 and step 7, you skipped a really important step…
