Ir para o conteúdo principal
GoPro Hero3+ Silver Edition Image Sensor Replacement
O que você precisa
    1. GoPro Hero3+ Silver Edition Image Sensor Replacement, Battery: passo 1, imagem 1 %32 GoPro Hero3+ Silver Edition Image Sensor Replacement, Battery: passo 1, imagem 2 %32
      • Push the tab on the back of the device left to remove the plate covering the battery.
      Pergunte ao FixBot
      Comentar
    2. GoPro Hero3+ Silver Edition Image Sensor Replacement: passo 2, imagem 1 %32
      • Use the strip of tape on the battery to remove the battery from the housing.
      Pergunte ao FixBot
      Comentar
    1. GoPro Hero3+ Silver Edition Image Sensor Replacement, Front Panel: passo 3, imagem 1 %32
      • Insert a plastic opening tool in between the front face plate and the black housing.
      • Make sure you insert the plastic opening tool next to the microSD card slot. There is a small gap that will help separate the face plate.
      Pergunte ao FixBot
      Comentar
    2. GoPro Hero3+ Silver Edition Image Sensor Replacement: passo 4, imagem 1 %32
      • Continue to use the plastic opening tool and separate the front face plate from the rest of the device.
      • There is adhesive that helps attach the front face plate. Some extra prying may be required to separate the face plate, but do not use excessive force.
      Pergunte ao FixBot
      Comentar
    1. GoPro Hero3+ Silver Edition Image Sensor Replacement, Image Sensor: passo 5, imagem 1 %32 GoPro Hero3+ Silver Edition Image Sensor Replacement, Image Sensor: passo 5, imagem 2 %32 GoPro Hero3+ Silver Edition Image Sensor Replacement, Image Sensor: passo 5, imagem 3 %32
      • Locate the four 8.1mm PH00 screws on the corners of the GoPro and unscrew them using the phillips screwdriver.
      • Gently remove the motherboard by using a plastic opening tool to pry it out of the housing.
      • Be careful not to damage the ribbon cable connected to the GoPro housing and motherboard.
      Pergunte ao FixBot
      Comentar
    2. GoPro Hero3+ Silver Edition Image Sensor Replacement: passo 6, imagem 1 %32 GoPro Hero3+ Silver Edition Image Sensor Replacement: passo 6, imagem 2 %32
      • Remove the ribbon cable by carefully flipping the black clip up with the plastic opening tool and pulling the cable out.
      Pergunte ao FixBot
      Comentar
    3. GoPro Hero3+ Silver Edition Image Sensor Replacement: passo 7, imagem 1 %32
      • Remove the four 4mm PH00 screws attaching the image sensor to the motherboard with your screwdriver.
      Pergunte ao FixBot
      Comentar
    4. GoPro Hero3+ Silver Edition Image Sensor Replacement: passo 8, imagem 1 %32 GoPro Hero3+ Silver Edition Image Sensor Replacement: passo 8, imagem 2 %32
      • Pry off the last ribbon cable with a plastic opening tool.
      • Remove the image sensor from the motherboard.
      Pergunte ao FixBot
      Comentar
Conclusão
4 outras pessoas executaram este guia.
Patrick Cook
Membro desde: 10/01/15
699 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 5-8, Maness Fall 2015 Membro de Cal Poly, Team 5-8, Maness Fall 2015
CPSU-MANESS-F15S5G8
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 33
Ao todo: 1,189
