Ir para o conteúdo principal
GoPro Hero3+ Black Edition Image Sensor Replacement
O que você precisa
  1. GoPro Hero3+ Black Edition Image Sensor Replacement, Battery: passo 1, imagem 1 %32
    • Pull the tab on the back of the device to release the back cover. It should come right off.
    • The device pictured does not include the back cover.
    Pergunte ao FixBot
    Comentar
  2. GoPro Hero3+ Black Edition Image Sensor Replacement: passo 2, imagem 1 %32
    • Use the battery tab to pull the battery out of the device.
    Pergunte ao FixBot
    Comentar
    • Remove the battery from the slot.
    Pergunte ao FixBot
    Comentar
  3. GoPro Hero3+ Black Edition Image Sensor Replacement, Front Face Plate: passo 4, imagem 1 %32 GoPro Hero3+ Black Edition Image Sensor Replacement, Front Face Plate: passo 4, imagem 2 %32
    • Using a plastic opening tool, pry the gray, front face plate until it can be removed from the housing.
    • To avoid breaking or weakening the tabs on the face plate which hold it in place, alternate the sides from which you pry and check each tab before separating the plate from the body.
    Pergunte ao FixBot
    Comentar
  4. GoPro Hero3+ Black Edition Image Sensor Replacement, Image Sensor: passo 5, imagem 1 %32 GoPro Hero3+ Black Edition Image Sensor Replacement, Image Sensor: passo 5, imagem 2 %32 GoPro Hero3+ Black Edition Image Sensor Replacement, Image Sensor: passo 5, imagem 3 %32
    • Using your screwdriver, remove the four 8.1mm PH00 screws securing the motherboard to the black housing unit and set them aside.
    • Use the plastic opening tool to help pry the motherboard/midframe up from the main housing. Once you can get a hold of the edge, simply pull the internal components up and out!
    • Watch out for the ribbon cable connecting the midframe and the motherboard to the GoPro housing. See the next step.
    Pergunte ao FixBot
    Comentar
  5. GoPro Hero3+ Black Edition Image Sensor Replacement: passo 6, imagem 1 %32 GoPro Hero3+ Black Edition Image Sensor Replacement: passo 6, imagem 2 %32
    • Remove the ribbon cable connecting the housing to the motherboard by flicking up the black clip with the spudger tool and gently pulling the cable out.
    Pergunte ao FixBot
    Comentar
  6. GoPro Hero3+ Black Edition Image Sensor Replacement: passo 7, imagem 1 %32
    • Once the internal components are removed, take out your handy dandy spudger tool and pry off the piece of tape that holds down the image sensor.
    • Disclaimer: Our device is just a teardown unit and no longer has the tape. The markup depicts the location where the tape would be located.
    Pergunte ao FixBot
    Comentar
  7. GoPro Hero3+ Black Edition Image Sensor Replacement: passo 8, imagem 1 %32
    • Using your screwdriver, remove the four PH00 screws securing the image sensor to the motherboard.
    • Disclaimer: The unit used for this guide did not include these screws. Set them aside so you do not mix them up with the previously removed screws.
    Pergunte ao FixBot
    Comentar
  8. GoPro Hero3+ Black Edition Image Sensor Replacement: passo 9, imagem 1 %32 GoPro Hero3+ Black Edition Image Sensor Replacement: passo 9, imagem 2 %32
    • Using the spudger tool, pry off the connector ribbon from the motherboard (don't worry it comes off pretty easily).
    • Remove the image sensor from the motherboard assembly.
    Pergunte ao FixBot
    Comentar
Conclusão
6 outras pessoas executaram este guia.
Kyle Rooney
Membro desde: 04/14/15
502 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 6-15, Maness Spring 2015 Membro de Cal Poly, Team 6-15, Maness Spring 2015
CPSU-MANESS-S15S6G15
4 Membros
Autoria de 13 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 11
Últimos 30 dias: 46
Ao todo: 2,665
