Ir para o conteúdo principal
GoPro Hero LCD Screen Replacement
O que você precisa
  1. GoPro Hero LCD Screen Replacement, Casing: passo 1, imagem 1 %32
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
    Pergunte ao FixBot
    Comentar
  2. GoPro Hero LCD Screen Replacement: passo 2, imagem 1 %32
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
    Pergunte ao FixBot
    Comentar
  3. GoPro Hero LCD Screen Replacement: passo 3, imagem 1 %32
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
    Pergunte ao FixBot
    Comentar
  4. GoPro Hero LCD Screen Replacement: passo 4, imagem 1 %32
    • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
    Pergunte ao FixBot
    Comentar
  5. GoPro Hero LCD Screen Replacement: passo 5, imagem 1 %32
    • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
    • Make sure to keep track of these screws as they are very small.
    Pergunte ao FixBot
    Comentar
  6. GoPro Hero LCD Screen Replacement: passo 6, imagem 1 %32
    • Carefully remove the motherboard and white plastic piece from the case.
    Pergunte ao FixBot
    Comentar
  7. GoPro Hero LCD Screen Replacement, LCD Screen: passo 7, imagem 1 %32 GoPro Hero LCD Screen Replacement, LCD Screen: passo 7, imagem 2 %32
    • Remove the larger ribbon cable from the daughter board by lifting the black latch and pulling the ribbon cable gently from the socket.
    • Disconnect the smaller ribbon cable leading from the white plastic piece by simply pulling it from the socket.
    Pergunte ao FixBot
    Comentar
  8. GoPro Hero LCD Screen Replacement: passo 8, imagem 1 %32
    • Separate the motherboard from the white piece of plastic.
    Pergunte ao FixBot
    Comentar
  9. GoPro Hero LCD Screen Replacement: passo 9, imagem 1 %32
    • Remove the ribbon cable from the motherboard by simply pulling the cable from the socket.
    Pergunte ao FixBot
    Comentar
  10. GoPro Hero LCD Screen Replacement: passo 10, imagem 1 %32 GoPro Hero LCD Screen Replacement: passo 10, imagem 2 %32
    • Separate the LCD screen from the motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
6 outras pessoas executaram este guia.
River Drake
Membro desde: 04/02/15
1.065 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 12-2, Lancaster Spring 2015 Membro de Cal Poly, Team 12-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G2
4 Membros
Autoria de 18 guias
3Comentários do guia
Where do you buy the replacement lcd
Anthony Volatile - Responder Compartilhar
Gopro hero 7 white repair cost:
Screen: $45 - https://www.ebay.com.au/itm/183828969944
Side panel: $35 - https://www.herogear.com.au/genuine-repl...
Addisen KING - Responder Compartilhar
I can find the screen but is it compatible with the Hero+
Brian Casado - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 23
Últimos 30 dias: 153
Ao todo: 27,247
