Ir para o conteúdo principal
GoPro Hero Battery Replacement
O que você precisa
  1. GoPro Hero Battery Replacement, Battery: passo 1, imagem 1 %32
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
    Pergunte ao FixBot
    Comentar
  2. GoPro Hero Battery Replacement: passo 2, imagem 1 %32
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
    Pergunte ao FixBot
    Comentar
  3. GoPro Hero Battery Replacement: passo 3, imagem 1 %32
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
    • Use a plastic spudger to pry the battery off from the white plastic piece underneath.
    • The battery is glued to the plastic so some force might be necessary.
    • Be careful not to damage the battery to avoid releasing dangerous chemicals.
    Pergunte ao FixBot
    Comentar
  4. GoPro Hero Battery Replacement: passo 4, imagem 1 %32
    • Remove the battery from the GoPro.
    Pergunte ao FixBot
    Comentar
Conclusão
29 outras pessoas executaram este guia.
River Drake
Membro desde: 04/02/15
1.065 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 12-2, Lancaster Spring 2015 Membro de Cal Poly, Team 12-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G2
4 Membros
Autoria de 18 guias
20Comentários do guia
The tutorial is excellent, even with a link to the tools needed, but no link to battery sale.
Could you please include this?
juliomap - Responder Compartilhar
Very good tutorial thank you. But I can also find no place to buy a new battery... But here is a petition to make Gopro sell spare parts: https://www.change.org/p/gopro-support-o...
maire - Responder Compartilhar
I followed these steps and inadvertently pulled not only the battery plug but its adapter (housing) at the same time. Now I can't plug the battery back in because there's no place to plug it! Contacting GoPro they stressed that the battery is not intended for removal.
erikwikstrom - Responder Compartilhar
Awesome! Could you also show us how to put in a new battery, how do i prep my battery? What type of a battery can i use ? Thanks a lot !!
John misquita - Responder Compartilhar
now add go pro to rice for a day and pray.
chadd23 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 44
Últimos 30 dias: 269
Ao todo: 83,824
