Ir para o conteúdo principal
GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement
O que você precisa
    1. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement, Back Panel: passo 1, imagem 1 %32 GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement, Back Panel: passo 1, imagem 2 %32
      • Be sure to power off the GoPro before you start disassembly.
      • Pop up and pull back on the clip to remove the screen cover and expose the back panel with the touchscreen.
      Pergunte ao FixBot
      Comentar
    2. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: passo 2, imagem 1 %32 GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: passo 2, imagem 2 %32
      • Use the metal spudger to pry around the perimeter of the panel.
      • Pry the panel upwards by inserting the metal spudger into the corner crease between the panel and camera shell.
      Pergunte ao FixBot
      Comentar
    3. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: passo 3, imagem 1 %32 GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: passo 3, imagem 2 %32
      • Pry around the panel to ensure it is not attached to the device.
      • Move the panel to the side so you can access the internal components.
      • The panel is still attached to the rest of the device with a ribbon cable, so be sure to not tear or damage the cable.
      Pergunte ao FixBot
      Comentar
    1. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement, Battery: passo 4, imagem 1 %32
      • Peel back the rear panel ribbon cable that is adhered to the battery until it is completely separated from the battery.
      • Be careful of metal contacts on strip; they can be sharp.
      Pergunte ao FixBot
      Comentar
    2. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: passo 5, imagem 1 %32
      Ferramenta utilizada neste passo:
      • Using tweezers, peel off the copper tape on the right side of the battery.
      Pergunte ao FixBot
      Comentar
    3. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: passo 6, imagem 1 %32 GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: passo 6, imagem 2 %32
      • Place the plastic opening tool at one of the edges of the battery then pry until the battery is removed from the GoPro.
      Pergunte ao FixBot
      Comentar
    4. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: passo 7, imagem 1 %32
      • Use a pair of tweezers to disconnect the battery connector from the motherboard.
      • Gently pull the battery off the motherboard. Pulling vertically off the motherboard will give a clean release.
      Pergunte ao FixBot
      Comentar
    1. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement, MicroSD/Micro USB Port Assembly: passo 8, imagem 1 %32 GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement, MicroSD/Micro USB Port Assembly: passo 8, imagem 2 %32 GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement, MicroSD/Micro USB Port Assembly: passo 8, imagem 3 %32
      • Remove the two 6 mm Phillips #00 screws.
      • Remove the single 4 mm Phillips #000 screws.
      Pergunte ao FixBot
      Comentar
    2. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: passo 9, imagem 1 %32
      • Remove the image sensor from the camera.
      • You do not have to unplug the black box to remove the USB/SD chip.
      Pergunte ao FixBot
      Comentar
    3. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: passo 10, imagem 1 %32
      • Grab the edge of the ribbon cable with the tweezers and gently pull until the cable is disconnected from the motherboard.
      • Be careful when removing the ribbon cable. You must pull gently or you can rip the ribbon off of its contacts.
      Pergunte ao FixBot
      Comentar
    4. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: passo 11, imagem 1 %32
      • Gently lift the microSD/Micro USB assembly up and out of the device.
      Pergunte ao FixBot
      Comentar
Conclusão
5 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 2-4, Blackwell Fall 2015 Membro de USF Tampa, Team 2-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G4
4 Membros
Autoria de 20 guias
2Comentários do guia
Hi were can i buy the microSD/Micro USB port assembly in your GoPro Hero+ LCD.
Hector - Responder Compartilhar
Very helpful guide
Ninigo Marine Contractor - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 36
Ao todo: 4,238
