Ir para o conteúdo principal
GoPro Hero+ LCD Battery Replacement
O que você precisa
    1. GoPro Hero+ LCD Battery Replacement, Back Panel: passo 1, imagem 1 %32 GoPro Hero+ LCD Battery Replacement, Back Panel: passo 1, imagem 2 %32
      • Be sure to power off the GoPro before you start disassembly.
      • Pop up and pull back on the clip to remove the screen cover and expose the back panel with the touchscreen.
      Pergunte ao FixBot
      Comentar
    2. GoPro Hero+ LCD Battery Replacement: passo 2, imagem 1 %32 GoPro Hero+ LCD Battery Replacement: passo 2, imagem 2 %32
      • Use the metal spudger to pry around the perimeter of the panel.
      • Pry the panel upwards by inserting the metal spudger into the corner crease between the panel and camera shell.
      Pergunte ao FixBot
      Comentar
    3. GoPro Hero+ LCD Battery Replacement: passo 3, imagem 1 %32 GoPro Hero+ LCD Battery Replacement: passo 3, imagem 2 %32
      • Pry around the panel to ensure it is not attached to the device.
      • Move the panel to the side so you can access the internal components.
      • The panel is still attached to the rest of the device with a ribbon cable, so be sure to not tear or damage the cable.
      Pergunte ao FixBot
      Comentar
    1. GoPro Hero+ LCD Battery Replacement, Battery: passo 4, imagem 1 %32
      • Peel back the rear panel ribbon cable that is adhered to the battery until it is completely separated from the battery.
      • Be careful of metal contacts on strip; they can be sharp.
      Pergunte ao FixBot
      Comentar
    2. GoPro Hero+ LCD Battery Replacement: passo 5, imagem 1 %32
      Ferramenta utilizada neste passo:
      • Using tweezers, peel off the copper tape on the right side of the battery.
      Pergunte ao FixBot
      Comentar
    3. GoPro Hero+ LCD Battery Replacement: passo 6, imagem 1 %32 GoPro Hero+ LCD Battery Replacement: passo 6, imagem 2 %32
      • Place the plastic opening tool at one of the edges of the battery then pry until the battery is removed from the GoPro.
      Pergunte ao FixBot
      Comentar
    4. GoPro Hero+ LCD Battery Replacement: passo 7, imagem 1 %32
      • Use a pair of tweezers to disconnect the battery connector from the motherboard.
      • Gently pull the battery off the motherboard. Pulling vertically off the motherboard will give a clean release.
      Pergunte ao FixBot
      Comentar
Conclusão
19 outras pessoas executaram este guia.
Kyle
Membro desde: 08/27/15
219 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 2-4, Blackwell Fall 2015 Membro de USF Tampa, Team 2-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G4
4 Membros
Autoria de 20 guias
13Comentários do guia
This is a superb guide but where can one buy a replacement battery? I have looked on the web for the one in your photo but can't find a specific one.
I want to buy one of these cameras but would like to know I can replace the battery.
Thanks.
Andrew - Responder Compartilhar
I am also trying to find the replacement battery for a Hero+. Have found a lot of batteries for all other versions of Gopro cams, but not one single one for a Hero+.
I have also sent an email to Gopro to get help. I am not prepared for an answer but I really would like to get hold of a battery.
Does anyone know how to get one?
Please contact me: rhafsrhafs@gmail.com. Rikard from Sweden.
Thanks
Rikard
Rikard Hård - Responder Compartilhar
hi, do you know where i can get the housing for the gopro hero+ lcd. mine is broken and need a new one but can't find it anywhere...........
chris
christianrisan - Responder Compartilhar
not even amazon?
Mary D'Alesandro - Responder Compartilhar
this is awesome thanks a lot! , i dont want to be rude, but the title says battery replacementnt , why isnt anyone preparing a battery and putting it back in?, All everyone is doing is taking th battery out
John misquita - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 36
Últimos 30 dias: 219
Ao todo: 42,393
