Ir para o conteúdo principal
Gigabyte P34G Hard Drive Replacement
O que você precisa
  1. Gigabyte P34G Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32
    • Remove all 15 marked screws on the underside of the laptop using a #0 screwdriver.
    • There are three different sized screws.
    • 1x 9.8mm Screw
    • 8x 5.6mm Screws
    • 6x 5.0mm Screws
    • Divide the screws by size and save them in a safe space for reassembly later.
    Pergunte ao FixBot
    Comentar
  2. Gigabyte P34G Hard Drive Replacement: passo 2, imagem 1 %32 Gigabyte P34G Hard Drive Replacement: passo 2, imagem 2 %32
    • Carefully peel back the two pieces of black tape holding down the cord.
    • Pull the marked tab straight up away from the board to disconnect the hard drive from the board.
    Pergunte ao FixBot
    Comentar
  3. Gigabyte P34G Hard Drive Replacement: passo 3, imagem 1 %32
    • Carefully lift the hard drive for removal.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
yeunghayden
Membro desde: 05/01/15
841 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 8-1, Regan Spring 2015 Membro de Cal Poly, Team 8-1, Regan Spring 2015
CPSU-REGAN-S15S8G1
5 Membros
Autoria de 12 guias
1Comentário do guia
Hi.
Can you please show me how to remove the back cover on the gigabyte sabre 17 laptop?
Need to change the hdd but cannot open the back.
Thank you.
Rizwan - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 13
Últimos 30 dias: 31
Ao todo: 3,830
