Ir para o conteúdo principal
Giant Reign 2 Headset Replacement
O que você precisa
    1. Giant Reign 2 Headset Replacement, Hex Screws: passo 1, imagem 1 %32
      • Using the 4mm Allen wrench, partially unscrew the 4 (22mm) hex screws on the front of the axle casing to allow the axle to slide freely.
      Pergunte ao FixBot
      Comentar
    2. Giant Reign 2 Headset Replacement, Axle Screw: passo 2, imagem 1 %32 Giant Reign 2 Headset Replacement, Axle Screw: passo 2, imagem 2 %32
      • Using the 8mm Allen wrench, loosen the axle screw until 1/2 of the axle screw is visible.
      • Push the axle screw to reveal the axle rod on the other side.
      Pergunte ao FixBot
      Comentar
    3. Giant Reign 2 Headset Replacement: passo 3, imagem 1 %32
      • Using the Allen wrench, finish unscrewing the axle screw and pull it out.
      • Hold the wheel when pulling out the axle rod so that the bike does not fall.
      Pergunte ao FixBot
      Comentar
    4. Giant Reign 2 Headset Replacement, Front Wheel: passo 4, imagem 1 %32
      • Pull the wheel from the fork.
      Pergunte ao FixBot
      Comentar
    1. Giant Reign 2 Headset Replacement, Headset: passo 5, imagem 1 %32 Giant Reign 2 Headset Replacement, Headset: passo 5, imagem 2 %32
      • Using the 8mm Allen wrench, unscrew 2 (32mm) screws to release the brake calipers from the fork.
      • If necessary use wire cutters to release zip ties attaching cables to the forks.
      Pergunte ao FixBot
      Comentar
    2. Giant Reign 2 Headset Replacement: passo 6, imagem 1 %32 Giant Reign 2 Headset Replacement: passo 6, imagem 2 %32 Giant Reign 2 Headset Replacement: passo 6, imagem 3 %32
      • Using the 8mm Allen wrench, unscrew the 30mm head screw located on top of the steam.
      • Using the 4mm Allen wrench, loosen the side screw on both sides.
      • Lift off the handlebar.
      • Hang the handlebar gently from the cables. Do not pull the cables as you may damage the brake/derailleur lines.
      Pergunte ao FixBot
      Comentar
    3. Giant Reign 2 Headset Replacement: passo 7, imagem 1 %32 Giant Reign 2 Headset Replacement: passo 7, imagem 2 %32 Giant Reign 2 Headset Replacement: passo 7, imagem 3 %32
      • Slide off the spacers.
      • Lift off the seal.
      Pergunte ao FixBot
      Comentar
    4. Giant Reign 2 Headset Replacement: passo 8, imagem 1 %32
      • Slide the fork out of the casing.
      Pergunte ao FixBot
      Comentar
    5. Giant Reign 2 Headset Replacement: passo 9, imagem 1 %32
      • Using your fingers, pry the bearings from the top and bottom of the headset.
      Pergunte ao FixBot
      Comentar
    6. Giant Reign 2 Headset Replacement: passo 10, imagem 1 %32
      • Apply WD-40 to both ends of the headset and bearings.
      • Dry headset and bearings with paper towels.
      • Repeat as necessary until clean.
      Pergunte ao FixBot
      Comentar
    7. Giant Reign 2 Headset Replacement: passo 11, imagem 1 %32 Giant Reign 2 Headset Replacement: passo 11, imagem 2 %32
      • Using your finger, apply all-purpose lube to the bearings and each end of the headset.
      • Insert the bearings into the headset with the beveled side facing into the headset.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 9-14, Amido Fall 2012 Membro de Cal Poly, Team 9-14, Amido Fall 2012
CPSU-AMIDO-F12S9G14
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 44
Ao todo: 4,687
