Ir para o conteúdo principal
Generic TV Remote IR LED Replacement
O que você precisa
  1. Generic TV Remote IR LED Replacement, IR LED: passo 1, imagem 1 %32 Generic TV Remote IR LED Replacement, IR LED: passo 1, imagem 2 %32
    • Starting to the side of the front LED, pry up the top of the remote.
    • Remove the top of the remote to expose the circuit board.
    Pergunte ao FixBot
    Comentar
  2. Generic TV Remote IR LED Replacement: passo 2, imagem 1 %32 Generic TV Remote IR LED Replacement: passo 2, imagem 2 %32 Generic TV Remote IR LED Replacement: passo 2, imagem 3 %32
    • Remove the circuit board by gently lifting it from the casing.
    • Flip over the board so that the leads of the LED are facing upward.
    Pergunte ao FixBot
    Comentar
  3. Generic TV Remote IR LED Replacement: passo 3, imagem 1 %32
    • Clip the leads of the LED.
    • Bend the LED downward until it makes a 90 degree angle with the circuit board.
    Pergunte ao FixBot
    Comentar
  4. Generic TV Remote IR LED Replacement: passo 4, imagem 1 %32
    • Desolder the broken LED using a soldering iron and desoldering braid.
    Pergunte ao FixBot
    Comentar
  5. Generic TV Remote IR LED Replacement: passo 5, imagem 1 %32
    • Solder the new LED in the same spot as the old one.
    • Make sure that the longer lead (positive) goes through the opening marked positive (+) before soldering.
    Pergunte ao FixBot
    Comentar
  6. Generic TV Remote IR LED Replacement: passo 6, imagem 1 %32 Generic TV Remote IR LED Replacement: passo 6, imagem 2 %32 Generic TV Remote IR LED Replacement: passo 6, imagem 3 %32
    • Make sure the buttons and the circuit board are placed correctly before reassembly.
    Pergunte ao FixBot
    Comentar
  7. Generic TV Remote IR LED Replacement: passo 7, imagem 1 %32
    • To check if your remote is now working, first make sure the batteries are in correctly. Then, press any button and aim the remote at a smartphone camera. If the LED is working, a red flashing light will be reflected in the camera.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 44
Últimos 30 dias: 130
Ao todo: 15,271
